... Can't you stand so that you're holding the bar pointing down the length of the garage instead of the width?
Possibly in theory but the garage is only 12ft total length and I have my motorcycle in there. For deadlifting normally cross-ways I can do it without having to move the bike - just pull right at the edge of the power cage. I leave the bar permanently set up with my starting weight and it doesn't get in the way. (Until today, at least. I had to move the bike out to set up the trap bar and the 7ft bar is currently propped up in a corner)... Can't you stand so that you're holding the bar pointing down the length of the garage instead of the width?
This was my thought too...
I remember someone posting similar here, but I can’t remember their reason for not doing this. I have to do similar in my home gym.
Morning all - decided to use a spare room for some weights, as opposed to the garage. It's a ground floor room with a concrete base, but also has the usual underlay/carpet over the top.
Any special considerations for laying rubber mats over the top of the carpet? Any particular flooring recommendations as well?
Personally I’d get a smith or hack squat as there’s more utility with those and you can still destroy your quads.Any reccomendations for a leg press? Bulldog gear do a nice one at £2000, just wondering if there are any other options that offer better value for money before buying?
I use an equipment mat since the carpet already provides some cushioning. If you wanted to beef it up you could put some thick mats either side for deadlifts.![]()
Yes, thick mats for deadlifts![]()
Been looking for a while to get some gym equipment for the garage but everywhere is out of stock!
I got a treadmill last year and now want to get some weights.
I saw this
https://www.powerhouse-fitness.co.u...er-olympic-weight-kit-and-bodymax-cf430-bench
But it hasn't been in stock for months and no idea when it will be
I have about 1k to spend so this looked great.
Can anyone reccomend anywhere else to buy from?
I did have a cheaper bar and bench a couple of years ago when I lived in a flat but my son was born and had to get rid to get a baby room. Now we have moved and settled i now have a garage for some home gym equipment!
