- 28 Oct 2011
The 3070 should have been 10GB and the 3080 Should have been 12GB imo.
Both should be 16GB.
Both should be 32Gb.
This is a fun game.
It's not as fun as defending NV as they cheap out on VRAM though.
They don't "cheap out", you do understand that if Nvidia added more vRAM to the card that it costs them to buy those RAM modules and they pass that cost on to you as a consumer. What do you think, that AMD are going to install 12Gb or 16Gb on their cards and then eat the costs out of their own profit margin, rather than pass on the costs of the memory on to the consumer because they're "didn't cheap out"?
There's an entire 80+ page thread on why 10Gb is enough for the 3080.
But yes this is a dumb little game. AMD are cheaping out because they're not putting 32Gb of vRAM on their cards. Anyone who disagrees is just defending AMD being cheap.
Thye do cheap out, they have a history of it, 3.5 GB 970 ripoff ring any bells?
If you can buy an 8GB card for £150 then 8GB on a £500 card is a sick joke.
But you feel free to keep on defending the big corps as they rob people blind. If AMD produce 8GB cards for £500 they'll be just as bad as NV.
Eurgh The memory split on the 970 happened because of the way the cores were fused off. The only way around that would be to use cores without defects and guess what a fully function core would have been called? Gm204-400...aka gtx980. If nvidia would have charged 980 prices for a 970 you'd have a point, but they didn't did they? The 970 was far from a ripoff. It was an exceptionally priced card. But let's not let facts get in the way of a good moan.
No because it had 4gb of addressable memory.Did they sell it as a 3.5GB card?
Case closed.
The 970 as James pointed out is an architectural limitation. And we've seen dual RAM config cards in the past but they're extremely rare. The 1060 had a 3Gb and 6Gb version and guess what, the 6Gb version was more expensive because if you add more RAM modules to a video card you have to pass on that cost to the consumer by charging more for the card. It's not "big corps" being "cheap". AMD are a big corp, they're putting 256bit bus on their memory is that cheap? They're using 16Gbps GDDR6 RAM and not GDDR6x RAM @ 19Gbps, is that "cheap"? Or how abotu we look at the performance of the cards when they're out and instead of judging them on vRAM we judge them on how well they perform at a given task?
vRAM does not give you your performance, the performance comes from the GPU itself not the memory. The memory only needs to be spec'd as big/fast as it needs to be to keep the GPU fed with data to produce the next frame. You're clearly judging the value of the card as related to how much vRAM it has and that's just wrong, it's a bad metric and if you do that you run the risk of making bad purchasing decisions.
AMD 8GB DDR6 GPU £188What do you think, that AMD are going to install 12Gb or 16Gb on their cards and then eat the costs out of their own profit margin, rather than pass on the costs of the memory on to the consumer because they're "didn't cheap out"?
But Nvidia knows that some people are just so easily pleased or connedhttps://www.overclockersclub.com/reviews/msi_rx_470_gaming_x_8g/
Couldn't find it for sale after a quick look around, but 2016 says hello with a 8GB VRAM GPU for $234...
But we're supposed to believe 8GB on a £500 card in 20/21 is "fine"?
Pull the other one it's got bells on...
But it wasn't what they sold it as, as they settled a false advertising lawsuit, so as I said a VRAM ripoff.
They sold it as a 4gb card. It has 4gb of usable ram. That's a fact. The lawsuit made a few claims, one of them was about the ram. It was incorrect. What the lawsuit was right about, though it really amounts to nothing, was the advertised number of rops and l2 cache. Nvidia misadvertised those two points, not that it made any difference to the performance of the card. But that's irrelevant when an American lawyer smells a class action lawsuit.
