The Ampere RTX 3090 Owners Thread
I don't think anyone has tried it with the founders yet as normally 3x8 pin card bios wont work with a 2x8 pin. This time around the fe is the card with the highest power limit for a 2 x 8 pin, so not much drive to try out other bios. Also the pcb is custom. So this may mean a stop.
However, there is a small hope. Last gen the evga xoc 3 pin bios worked on the 2x8 pin founders. They have just released a 500w beta version, so maybe someone will try this out soon.
Ah ok yeah makes sense, will be interesting to see if anyone trys it... certainly wont be me though heh.
Haha, it was a bit of a mission.
I took the PSU shroud out first - that was a pain! (ignore the PSU, new one on the way)
Then dremelled the back out, so I can fit a 3 slot card. (also dremelled the front to make space for the radiator)
Then I 3d printed a bit of plastic to support the card
Finally, spray painted the glass to hide the PSU/cables
I know I could've just bought a new case, but where's the fun in that! Most of the parts are from my H1.
What cpu are running and how are the temps?
Can somebody due to me favor? Can you run on rtx 3090 on stock clocks and stock cpu , timespy run and show graphic score? + only with BALANCED POWER PLAN
I am gettin gpu score 18.000+- on balanced. On max perf is normal 19.000K
Threadripper 2950x at stock with ryzen balanced power plan, 3090 FE at stock.
I see EKWB have updated their waterblock for the Asus Strix release date to late November... I guess no 3090 for me before Cyberpunk.
anyone swapped out the bios on an MSI ventus OC?
350watt power target and limit is a JOKE!!!!
needs 390watt gigabyte bios on asap
I hear you lose a display port but that's about it
Took delivery of this around a week ago, block is pre-ordered and due any time now....
p.s. As far as I've seen, this is the first XC3 3090 on here
Welcome and on TROH.:)
The Roll of Honour.
Date 22/10/2020, Make EVGA XC3 Ultra, Skwizle, Link
Date 21/10/2020, Make NVidia FE, mastrchee, Link
Date 21/10/2020, Make NVidia FE, MidKnight, Link
Date 21/10/2020, Make NVidia FE, southy1978, Link
Date 21/10/2020, Make NVidia FE, Private Custard, Link
Date 20/10/2020, Make PNY XLR8, Cosimo, Link
Date 20/10/2020, Make Palit GamingPro, Brok, Link
Date 20/10/2020, Make NVidia FE, Stu999, Link
Date 20/10/2020, Make NVidia FE, scrivz69, Link
Date 20/10/2020, Make NVidia FE, pyxis_00, Link
Date 19/10/2020, Make MSI Gaming X Trio, sd1cko, Link
Date 17/10/2020, Make Zotac Trinity, wickfut, Link
Date 17/10/2020, Make Asus TUF, WhiteHawk77, Link
Date 17/10/2020, Make Palit GamingPro, jimmy321, Link
Date 17/10/2020, Make Asus Strix, DxFlame, Link
Date 16/10/2020, Make Palit GamingPro, Jarrastafari, Link
Date 16/10/2020, Make Zotac Trinity, Jarrastafari, Link
Date 15/10/2020, Make Asus Strix, Drazek, Link
Date 14/10/2020, Make Gigabyte Gaming, darkBytes, Link
Date 13/10/2020, Make MSI Ventus X, cadmunkey, Link
Date 11/10/2020, Make MSI Gaming X Trio, ketma, Link
Date 10/10/2020, Make MSI Gaming X Trio, bemaniac, Link
Date 10/10/2020, Make Gainward Phoenix, Jose, Link
Date 08/10/2020, Make Gigabyte Gaming, Zsooo, Link
Date 08/10/2020, Make Asus TUF, Marc250, Link
Date 06/10/2020, Make MSI Ventus X, kitkat9933, Link
Date 06/10/2020, Make NVidia FE, cHk4, Link
Date 06/10/2020, Make NVidia FE, Quare Crack, Link
Date 05/10/2020, Make Zotac Trinity, m4rmite, Link
Date 05/10/2020, Make NVidia FE, tatts, Link
Date 04/10/2020, Make NVidia FE, Addicted, Link
Date 04/10/2020, Make MSI Gaming X Trio, xb8browney, Link
Date 02/10/2020, Make Palit GamingPro, 0121danwilliams84, Link
Date 01/10/2020, Make Gigabyte Eagle, Sedgey123, Link
Date 30/09/2020, Make NVidia FE, RexAlba, Link
Date 29/09/2020, Make Asus TUF, Bigminimus, Link
Date 29/09/2020, Make NVidia FE, Strife212, Link
Date 29/09/2020, Make Asus TUF, BaueruTc, Link
Date 26/09/2020, Make Gigabyte Gaming, malachi, Link
Date 26/09/2020, Make Gigabyte Gaming, 1nfern0, Link
Date 26/09/2020, Make Palit GamingPro, Jay85, Link
Date 25/09/2020, Make Asus TUF, Cubed, Link
Date 25/09/2020, Make Palit GamingPro, jabski, Link
Date 25/09/2020, Make Asus TUF, MestasDeejay, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3090
Looks to be some driver issues with the 3090's, Gsync and Nvidia surround at the moment :(
Since putting in my 3090, I had been struggling with what's shown in the video, basically.. it not working and major system instability, but also it gets worse at the very end of the clip, what almost looks like the GPU is dying/dead.
The following video shows
(1) enabling nvidia surround - 2 screens go blank and the system becomes very unstable, I have to force power off.
(2) a clean boot with nv surround enabled, resulting in major artifacting on 2 screens. The only way back from this is to disconnect the screens to force it back to a single screen.
Its a boring clip though, so apologies in advance :D
I changed cables and tried everything I could think of for hours... but the last thing I tried was disabling Gsync, It didn't cross my mind before, since I had just upgraded from a 2080 ti that was perfect.
So, just an FYI for anybody who uses Nvidia surround and Gsync monitors and has or is getting a 30 series. If you have the above issues, disable gsync for now, it then works (without gsync ofc) and is stable.
I take it you had those monitors working in surround with gsync active on previous card?
Asking as it does look like a cable issue
Edit, I take that back... looks like the card.
Pretty sure its a driver issue, without gsync it works perfectly, so guess I just have to cross my fingers for an update (I have opened a ticket) but was mainly posting here just to let people know.
I did have cable issues when I first set it up about a year or so ago, that usually results in similar behaviour of one screen going black / flickering, admittedly, but not the corruption thing.
But I sorted that... It still didn't stop me considering though, you can still see one of the original cables dangling where I swapped them out.
Arrived all the way to Dubai from the UK today
The Roll of Honour.
Date 24/10/2020, Make NVidia FE, ronski, Link
Hey!
Just came upon this thread,
Received my card around 1 month ago now (27/09/2020) - Fantastic card! Been using it heavily for some sim racing games like Assetto Corsa competizone and iRacing and its been fantastic. Playing at 4K so the extra oomph has been worth the premium.
08uH0yM
08uH0yM
Photo is a bit awkward as its been installed for ages now but you can just about make out the 3090 on the sticker. Was lucky enough to get one of the few cards at launch.
