Is there anywhere I can buy a Nomad case in black for the 12 pro? Or any other case that is of similar quality.. Cheers
Megamac
Megamac
Thanks, I had a look.. It says Stock: 7 business days.. So I assume upto 10 days for delivery, I believe the handset is arriving tomorrow so looking for somewhere with it in stock to order, cant seem to find anywhere
Classic Apple. Have they created a new PD profile just for the MagSafe charger thus guaranteeing not a single other charger out there is able to deliver 15W?Looks like I made the right choice with the official 20w adapter to pair with the MagSafe. It’s the only adapter that allows for the full 15w using MagSafe.
https://www.macrumors.com/2020/10/26/magsafe-charger-needs-20w-power-adapter/
Check out the video. Even a 96W Apple charger doesn’t reach 15W, nor does last year’s 18W iPhone charger, yet the brand new 20W charger reaches 15W consistently. PD chargers are following a protocol, a standard. So the charger only provides what the thing being charged (in this case the MagSafe charger) requests.Pretty sure that would be illegal as an anti competitive practice? Might be wrong
Same here. 14.2 is available for the new phones, I just set up as a new phone, enrolled the new phone for the beta, did the upgrade and then erase and wipe all settings. Then set up again and transferred over from old phone.Did anyone else get themselves in the position where their current iPhone is running iOS 14.2 beta and are wanting to restore a backup onto their new 12? What would be the simplest way around this, should I set up the 12 as new, update to 14.2 beta and then restore?
You can still use the regular iPhone chargers, there’s no real reason you need the USB-C version. Most charge overnight and that provides enough power.Not only that but the cable in the box is USB-c to lightning, so saying that you can use the charger you already have to save on the environment is not true, as I think only last year they started with the USB-C in the box, anyone with earlier iphone will have a charger they can't use with the new cable.
Oh I know that, but I think the point still stands that they include a cable but state you can use your existing wall charger which isn't compatable for the majority.You can still use the regular iPhone chargers, there’s no real reason you need the USB-C version. Most charge overnight and that provides enough power.
Wow take a look at this...
So it seems as if, no matter what charger you use with the magsafe, it wont get upto 15w wireless charging and only works with the 20w brick that they're now selling!
Thought the same when I read that. What a con.Pretty sure that would be illegal as an anti competitive practice? Might be wrong
the monthly cost is £13 per month due to a perk with work
