I dont know what they do honestly.I had much more trouble overclocking ram on one of these compared to my B450 tomahawk max.
I think its down to a cold booting voltage issue as even when getting the ram prime and overnight ram test stable a week or so later it would fail to boot and reset to default.I dont know what they do honestly.
I mean it all depends on the kit. I always look at latency and transfer rate results to determine if the overclock is working.I think its down to a cold booting voltage issue as even when getting the ram prime and overnight ram test stable a week or so later it would fail to boot and reset to default.
Also at 3733 I wasn't able to lock in trdrd lower than 17 whereas on my B450 tomahawk I was able to set 3800 14/14/14 with the same ram type etc but maybe my brother just got a duff kit.
They might be of different quality. I remember DRAM Calculator had a thing where you could check the quality %, though I dont know how accurate that was.They are both 8 pack B-die kits so should perform well.
3.61 boys
Update AMD AGESA ComboAM4v2 1.1.0.0 Patch C
I only checked because I am getting a 5800X today, and wanted to makes sure it was the latest one lol
Cheers!
According to Tom at OC3D and also mentioned by Kit Kuru, AMD said patch c will unlock IF @ 2000mhz for those chips capable.
Nice to know, thank you.Cheers!
Can you post a screenshot of HWINFO64 showing what you mean? I believe the CPU voltage will be locked at 1.4v ish for a few minutes after Windows boots. But after 5 min or so it should drop assuming the system is truly idle.I have an odd problem.
I have just received my 5950x. It works fine, but according HWinfo the average voltage on all cores is 1.45V+. I haven’t had time to do much, so that is just on desktop with a few browser tabs open, with 80% of the cores asleep. HWinfo seems to report the clock speeds correctly. Ryzen Master shows an average voltage of 0.5V (I think, maybe have misread it, but it definitely looked ok).
I am currently on bios version 3.61, but tried 3.40 too. I haven’t changed any settings. I installed the latest AMD chipset driver and I use the balanced power plan. I tried the latest stable and beta versions of HWinfo (6.34 should support the new processors). I haven’t reinstalled Windows or cleared CMOS yet.
Is anyone having similar issues with HWinfo? As far as I remember it worked fine with my 3700x regardless of the bios version.
PBO does not work at all for me.
