Time Spy Standard DX 12 Bench.
I will have a look but I doubt the extra 5w would turn into the 500 points needed ;)
Yeah my fans are 100% flat out when set to 495w although it doesn't do to bad the cooler with the card sitting around 75 degrees... not to bad considering its dealing with nigh on 500w but its crying to be put in a water block :D
you might of 'blipped' 495watt but officially...
your card is:
Board power limit
Target: 390.0 W
Limit: 480.0 W
https://www.techpowerup.com/vgabios/224964/asus-rtx3090-24575-200909
your bios is the
VBIOS Version: 94.02.26.C0.16 or 94.02.26.C0.13 ?
My 3090 Strix arrived from OC today at last , quick manual oc and this was the result .. should be able to push it further on the weekend when I've got more time to play :D
https://www.3dmark.com/3dm/52293127?
Score : 20547
Gpu score :21938
Cpu Score: 15117
Intel i9-10900K @5.2Ghz
Asus Rog Strix 3090 Oc , +146 core , +640 memory in afterburner
Driver 457.09
impressive. I have the same setup but only getting 18500
Current bios is : 94.02.26.C0.16
Will have a look at getting the bigger power one on ... unlimited would be nice ;)
Anyway have a new update to my score which i will post below :D
seems like I had a dud 3090 core!
as it didn't hold the MHz and dropped more often and lower then my friends card, he's around 200/300 points in port royal better.
goes to show its about as silicon lottery as is Power limit.
Update to my Score , Put the Cpu at 5.3Ghz rather than my daily 5.2Ghz which has increased the score a little ... every little helps and all that ;)
https://www.3dmark.com/spy/14900131
Score : 20735
GPU Score :22030
CPU Score : 15557
Intel i9-10900K @ 5.3Ghz
Asus Rog Strix 3090 Oc , with manual oc in afterburner +146 Core , +600 Memory
Driver: 457.09
Quick Timespy with my Asus 3090 OC Strix with no overclock just power and fans set to max. CPU not overclocked either just PBO on. Ill do all the overclocking stuff when the waterblock arrives.
Score - 20017
GPU - 21112
CPU - 15473
AMD 3950X - PBO
Asus Rog Strix 3090 OC - Stock
https://www.3dmark.com/3dm/52369304
Drivers: 457.09
Score - 20017
GPU - 21112
CPU - 15473
AMD 3950X - PBO
need to include the 3dmark link and driver used :)
Updated score after a bit of overclocking. Im sure there is some headroom left as my CPU score is quite low, however Ill be getting the 5950X this week and still waiting for thew water block.
Score - 20907
GPU - 22235
CPU - 15624
Asus Strix 3090 OC +160 Core +1100 mem (EVGA 500W BIOS)
Drivers 457.09
https://www.3dmark.com/3dm/52451784
