I will have a look but I doubt the extra 5w would turn into the 500 points needed
Yeah my fans are 100% flat out when set to 495w although it doesn't do to bad the cooler with the card sitting around 75 degrees... not to bad considering its dealing with nigh on 500w but its crying to be put in a water block![]()
you might of 'blipped' 495watt but officially...
your card is:
Board power limit
Target: 390.0 W
Limit: 480.0 W
https://www.techpowerup.com/vgabios/224964/asus-rtx3090-24575-200909
your bios is the
VBIOS Version: 94.02.26.C0.16 or 94.02.26.C0.13 ?
