- 14 Mar 2011
As above - not anywhere close to £20k but I have my 3 guitars hung on the wall behind me... it's a stud/partition wall so what I did was get a good solid piece of 1x4" which is mounted horizontally and screwed into the wall studs in 3 places using 2 decently long thick screws each, and then the guitar hangers are each attached to that with pretty big screws too (that technically stick through it slightly and into the plasterboard) - no way would it come down. Have had them hung there for years with no problems - I suspect the only situation you might want to be careful of with hanging would be if the room they are in experiences very large fluctuations in humidity and/or temperature (but that is kind of a problem for guitars regardless)
