G. Skill announces memory for AMD 5000 series
10 Dec 2007
https://www.gskill.com/community/15...DDR4-4000-CL16-16GBx2-for-AMD-Ryzen-5000-CPUs
"G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is announcing new DDR4 memory specifications under the Trident Z Neo series, optimized for the new AMD Ryzen 5000 processors. Featuring ultra-high speeds of up to DDR4-4000 CL16-19-19-39 32GB (16GBx2), extreme low latency at DDR4-3800 CL14-16-16-36 32GB (16GBx2), and high-capacity kit at DDR4-4000 CL18-22-22-42 64GB (32GBx2), these memory kits are the perfect choice for PC enthusiasts and gamers looking to push memory bandwidth to the extreme limits on the new AMD Ryzen 5000 processors."
A nice table:
As we can see G. Skill is trying to cater to every single FCLK speed.
"These ultra-speed, high-capacity, and extreme low latency memory kits will be available via G.SKILL worldwide distribution partners at the end of November 2020".
Hopefully DRAM calculator gets updated since it seems now 5000 series will be able to hit 4000Mhz with new BIOS updates.
Are these guaranteed to be samsung b-die? If the 2x16gb modules are dual rank then these are kind of perfect. 32gb ram, 2 sticks, low latency, 4rank total.
Just to add even more confusion to the ongoing single rank / dual rank fiasco, the gskill 3600 cl14 (4x8 sticks) appear to all be dual ranked... if one stockist’s description is to be believed.
Order the 32GB 3600 set last night (F4-3600C14D-32GTZR).
You know that is Trident Z RGB not Neo right (Neo has the suffix GTZNC)? I think the Neo has the XMP settings tuned for Ryzen.
I was looking at the new CL14 packs but I picked up 4x16GB 3600C16 Neo for £340 instead. Looks like a big price premium for the CL14.
