- 21 Jul 2005
- Officially least sunny location -Ronskistats
Patience young chicken. Greedy TNA has backup plan.
I should say that was when I had assassins creed origins running. Could vary game to game, but it is noisy. When I shut the game down it quietens and goes back down to like 51 degrees.
Patience young chicken. Greedy TNA has backup plan.![]()
I always seem to miss the drops.at minimum yes. Doesn't bother me although maybe it is a little to do with air circulation inside my case too I dunno.Your idle temp is 51 degrees?![]()
well the fan speed is only on like 73% If I put it on 100 is is just extremely noisy. Wish I had a watercool loop in my system now, so I could install a waterblock.OK. Just checked mine's at 26 degrees, wife has heating on, its a vega GPU yanno AMD's run hot!![]()
Yea I did. Been dispatched already too
I had latest drivers and tried to swap 1660 super to 3080 and Windows just uses basic graphics adapter driver and keeps flashing screen trying to enable 3080. I tried uninstalling and reinstalling drivers. No use. Reinstalling windows nowMy current driver for my 2070 super is the same driver as the 3080. If I’m doing a straight swap, would I still have to uninstall and reinstall drivers, or could I just swap the cards?
@Kaapstad Scratch that, it just arrived, will get a picture up shortly![]()
Haha. Will take a picture and put it up in kaaps threadNo. Frigging. Way.
#pretendnotjealous
I have a phanteks glass side midi case. I have a semi modular psu so don't have excess cables everywhere. Could upload a pic. Might be easierWhats your case like buddy, it should have better airflow than that?
Did you sign up to a distill group or use something else?Thanks![]()
