Nice, was that fairly easy?
 I shall try more tomorrow.
AMD Fans: INTEL GOT COMPLETELY DESTROYED IN GAMING!!!!111
Checks some sites for reviews and it seems that Zen 3 has around the same performance/advantage Intel had over Zen 2 in gaming. Non gaming Intel got destroyed
Some of you need to dial it back abit as some are worse than clickbait Youtubers.
Looking around the net wins like that ^^^^ are not that unusual, most Zen 3 is only around 10% faster, and losing in a couple of games, but there are enough of these big margin wins for AMD to add to the smaller wins and make the whole thing really quite shocking, in some games AMD have managed as much as <50% higher performance vs Zen 2, and here's the thing, where AMD wins big its in games where with Zen 2 AMD lost big, for example that ^^^^, Serious Same 4 is another where Zen 2 was bad in comparison and now AMD are 15% faster than Intel, Far Cry 5 is another huge jump for AMD, CS:GO AMD complete take the pee.....
This is the gob smacking thing about it, everywhere in gaming where AMD did unusually badly vs Intel they are now smashing it, its almost as if Intel thinking "its ok we have sevral of these games where AMD are so far behind they would need 30% to match us and that's not happening...." AMD be like "Think again Intel!"
The big wins are probably the same places the Ryzen 5 3300X also improved,ie,latency is what held back Zen2 CPUs. I remember saying a while back the biggest improvements in Zen3 will be in games where the latency of the 4+4 CCX design causes problems.A lot of those are older games,or those based on older generation engines. Even with Intel look at the HEDT CPUs with the mesh bus and the consumer CPUs with the ring bus which was lower latency, and despite the same cores,the latter was faster in many games.
Any engine or game which is more CCX aware will have lower improvements,and I suspect Zen2 will also hold its own in future multi-platform games,because the consoles use it.
Are all 3300x cpus single ccx? Iv seen they are quite good sometimes beating a 3600. I'm probably going to pick one up in town tomorrow to use whilst I wait for the 5900x.The big wins are probably the same places the Ryzen 5 3300X also improved,ie,latency is what held back Zen2 CPUs. I remember saying a while back the biggest improvements in Zen3 will be in games where the latency of the 4+4 CCX design causes problems.A lot of those are older games,or those based on older generation engines. Even with Intel look at the HEDT CPUs with the mesh bus and the consumer CPUs with the ring bus which was lower latency, and despite the same cores,the latter was faster in many games.
Yeah, you might be on to something there, a combination of the +19% IPC, clock speeds and unified L3 would explain the up to near 50% jump in performance.
Well that's great if your running CSGO on a 680hz monitor then.destroyed!
What's strange here is the consoles all have 8/16 threads. Yet the top gaming chip on PC is the 5600x.
So is 6/12 still a good idea on the PC in light of next gen games?
Apparently it is is the only mobo that lets you set a manual overclock and still retain the high single core boost.
