 - 19 Jan 2007
 - Up a Tree
I wonder if anyone else on the forum would be able to offer a loaner cpu, someone that has already upgraded to zen 3.
I don't understand why AMD needed to release this 5000 series without any support - not a single board that supports the new CPUs out of the box, as is?
So amateurish, so painful to watch or try to explain. Just plain stupid and anti-user.![]()
It would delay them by months if they did that as it would take time for updated stock to reach retailers. Also, retailers would need to flash any existing stock, which is not feasible.
They could have pulled an Intel and change the socket every 6 months.
Only if your motherboard supports USB FlashBack....which is only on the ROG series of the Asus boards (and probably other manufacturers, I'm just dealing with an Asus board). You can tell those that do as they have a bios button on the I/O panel.Nowadays you can flash bios without CPU installed![]()
AMD said:Thank you for your request to loan a boot kit from AMD.
Before approving your request, I would like to verify that you have tried to contact your motherboard manufacturer or their local authorized service provider, and they have established that your motherboard requires a BIOS update, and were not able to help you perform that update.
Please provide a summary or copy of your communication with the motherboard manufacturer to indicate why support from the Original Design Manufacturer (ODM) is not suitable.
NOTE: Some motherboards are designed to support “USB BIOS Flashback,” which allows for BIOS updates from a flash drive even if the current BIOS on the motherboard does not have the software code to boot a new processor. Such motherboards feature special hardware to enable USB BIOS Flashback, and every manufacturer has a unique procedure to execute USB BIOS Flashback. Check your motherboard’s user manual to see if USB BIOS Flashback is supported. If it Is supported, follow the steps described in the manual or support documentation to perform the BIOS update.
If the motherboard manufacturer is unable to assist, and your motherboard does not support USB BIOS flashback, AMD is in position to be able to provide a short-term loan of a Boot kit, such that you can Flash the BIOS yourself.
To qualify for this service, AMD will require a picture of your Ryzen processor that clearly shows the Model number and Serial number plus a copy of your purchase invoice.
Please Note: A picture of the retail box is not sufficient
List of qualifying parts:
Ryzen 9 5950X
Ryzen 9 5900X
Ryzen 7 5800X
Ryzen 5 5600X
Ryzen 9 3950X
Ryzen 9 3900X
Ryzen 7 3800X
Ryzen 7 3700X
Ryzen 7 2700X
Ryzen 7 2700E
Ryzen 7 2700
Ryzen 5 3600X
Ryzen 5 3600
Ryzen 5 3400G
Ryzen 5 2600X
Ryzen 5 2600E
Ryzen 5 2600
Ryzen 2500X
Ryzen 5 2400G
Ryzen 5 2400GE
Ryzen 3 3200G
Ryzen 3 2300X
Ryzen 3 2200G
Ryzen 3 2200GE
Please can you also provide a picture of your motherboard clearly displaying the make and model number.
* By submitting these details, you agree to the attached terms and conditions of AMD’s Boot Kit loan.
Once we receive this information, we will be happy to review your claim to establish legibility for a Boot Kit loan.
If you no longer require this service, no response is required.
In order to update this service request, please respond, leaving the service request reference intact.
Best regards,
Markus
AMD Global Customer Care
Quick splash of acetone, swap of CPU, scrape the bottom of the Kryonaut barrel and......she LIVES! She's a nat's toasty at times on a 240 AIO with the speeds turned down (curve favouring peace and quiet) but I guess that's what happens when you suddenly turn all 12 cores up to over 4.5GHz. This isn't an overclock - all at stock - it's boosting to 4.5 on all cores and I've seen a couple hit 4.95. Shove a decent custom loop on there and you'd be laughing. Definite warm breeze wafting out the front from the rad though - even at mainly idle.
Firecuda 520 (512 GB) hit 5GB/s by 2.5GB/s on a 1GB test in Crystal DiskMark 7.
