Aye just read Gibbos update and its already slipping sliding towards Xmas.
https://forums.overclockers.co.uk/posts/34202186
I just canceled my order for 5900 and decided not to switch from mac to PC as if what apple said about M1 is true Intel and AMD are in big trouble. I'm using my machine for development and until now Docker was a big pain running due to its volumes mapping. ARM based systems are not having this problem and M1 matching the performance of 5900 and 5950 and being much cheaper is a game changer
Great, another clown fiesta hardware launch. Can't wait for the 6800 ****show next week.
Major US retailers now informing pre order customers they aren;t expecting any more stock until March 2021!![]()
The only big advantage of ARM CPUs is power efficiency. Not actual raw speed. And nowhere Apple claim these new ARM ones will be faster. All they say is that they will be perf/W king - and that's fine, mobile CPUs already are. But that aside, they're WAY behind top Intel/AMD CPUs with raw performance. They instead use mobile approach to clocking down and switching between BIG/small cores to keep power usage to minimum. Quieter computers, less heat, much longer battery life. But definitely not more raw speed, not even close.
So, depending of your use case, you might be very disappointed with M1. Raw performance is not what Apple want nor aim at, it's portability, silence and battery life with still good enough performance in Apple software.
It doesn't match their performance, go back and look at what they actually said, it matches the performance per watt (presumably of an outdated Intel chip), that's great news if you're after efficiency but much less so in raw performance. Your reaction is exactly what Apple wanted though.
There are other issues to consider, once Apple moves over to ARM they truly become a closed platform, which is fine if you have modest needs or your main tools are supported but if you intend to do anything like game, run Windows apps etc you've got a problem.
That is so true, it is a closed platform, but as I'm not a hardware enthusiast but rather into software if they give me lots of performance on a reasonable price I will get it. My gamers days are long over.
seen stock (10) of the 5800X available this morning elsewhere online but they are charging more than the MRSP of the 5900X for the 5800X
Yeah, ocuk is now over £100 more than list for the 5950x. Worst retailer I saw is one that has 5800x for preorder or for an extra £110 they can buy their "queue priority" package and have one in stock delivered tomorrow.
Thats just scummy
I get people got to mak money but surely there should be some form of consumer protection against this sort of thing. People are buying them though, shop i saw has gone from 10 down to 3 in stock now
Or even a forum thread that was locked with all info on 5000 series launch. That would have been great
It's not, i get a forum errorAt the moment, @Gibbo is posting in the initial announcement thread and this link should show only his posts in there, but it's not quite the same.
You don't have companies doing that with food in our supermarkets - it stays at list price.
