Easy to read sig says Acer predator![]()
You’re reading my sig mate, I was asking the other guy. I have the X27 and I was curious what he had since there aren’t many monitors that are capable of doing the 3090 justice yet
So afterburner isn't giving me any options for voltage controll on my inno x4 3090 am I missing something ?
And is it normal for this card to sit at 83c under a gaming load? Seems abit high to me
isnt 83 degrees the temp limit is msi afterburner?So afterburner isn't giving me any options for voltage controll on my inno x4 3090 am I missing something ?
isnt 83 degrees the temp limit is msi afterburner?[/QUO
That's the default target temp after which clock speeds will taper off significantly to stay within 83 degrees. You already do lose clock speed as you get hotter, but is more aggressive when you do hit 83 degrees. So ideally would want to keep below that.
How you finding the gaming x trio I have one on the way.My Trio is about the same, but i've undervolted mine now so its ~68c
I did have a zotac but power limit is way to low.
Just arrived![]()
Palit GeForce RTX 3090 GameRock OC 24GB . Added a second one to the family.
Finally managed to figure out how to post an image (I hope!)
