Just a heads up. You are arguing with an admitted dup. account.
https://forums.overclockers.co.uk/posts/34242882
Which post has the admission? I can see an accusation.
Its through something called omission. He never denied that he was shaz. Who i was originally replying to.Which post has the admission? I can see an accusation.
Its a bit faster than a 2080TI in RT, the 3080 is 29% faster than the 6080XT.The stock 6800xt gets 8873 in port royal and the overclocked 6800xt gets over 9000. Yet the review shows over 9000 in port royal as stock. CPU does not affect PR at all, its all GPU. SAM does not affect it as well. Only overclocking.
This is the normal stock 6800xt in Port Royal. https://www.guru3d.com/articles_pages/amd_radeon_rx_6800_xt_review,27.html
then 9143 points. https://arstechnica.com/gaming/2020...view-the-1440p-gpu-beasts-youve-been-craving/
is it overclocking? yes. see here. https://www.overclock3d.net/reviews/gpu_displays/amd_radeon_rx_6800_and_rx_6800_xt_review/20
So overclocking the 6800xt to 2.4GHz gets you 9116 points. https://www.overclock3d.net/reviews/gpu_displays/amd_radeon_rx_6800_and_rx_6800_xt_review/5
This last benchmark confirms stock at 8934.
So some reviews likely have special 6800xt's so be careful.
Look at the trees, there is defiantly more LOD culling on the 3080, more shader rendering on the left image, and yes, where are the water splashes on the Nvidia side?
Should have gone to Specsavers. They are at two different locations on the track. On the 3080 side the car hasn't even reached the water. No idea what's going on with the 3080 here, but the game has numerous bugs hence the poor Steam reviews.
3080 side (right) second tree in from the right is the 1st tree on the AMD side. That alone cleary highlights that the Nvidia car has not reached the water yet.
That's untrue - the Nvidia car "never reaches" the water - there are never water splashes on the right screen. Watch the video.
NVIDIA drivers usually circumvent game code. To give some sort of image quality advantage. In this case it broke the games image quality instead of helping them. Which is why you see that anomaly. In my opinion.Is the sun behind a cloud the entire time for the Nvidia run or what.
now I understand why you're so easily marketable. In your reply its apparent it would take somebody to say, "yes I did..blah blah blah" before posting the difference between right and wrong.There is only the accusation, its just Eastcoast being Eastcoast I'm afraid...
All this commotion over some water splashes
