What is the pipe called?
15 Sep 2009
Birmingham
This may well be a really dumb question but on the outside wall of my downstairs toilet, there is a small pipe that comes out of the wall and has a T shape at the end
Well was before it was broken and now is just a broken pipe sticking out the wall.
Does anyone know the proper name for this pipe so I can get a replacement? I've tried google but not knowing the name, can't find anything...
There is another out of my upstairs bathroom so presume its a ventilation or condensation sort of pipe?
7 Sep 2020
Gods Country
Toilet overflow pipe
20 Feb 2009
Rugby
If it's ~20mm, it's most likely a 21.5mm overflow pipe. If it was a T piece, you probably want something like this to replace it.
I'd potentially be concerned over the damage to the pipe though, a new t piece might not have enough pipe to join onto.
