Garage possibly messed up part installation - need proof
OP
17 Feb 2006
Winchester
Shouldn't they also be covering the cost of work the second garage carried out. If they had fitted it correctly on the correct side you would not have needed to get the OSR bearing replaced.
Yes, that is true, but I don't mind letting that slide because at the end of the day, I have got a new part installed which I may have had to change in future anyway.
18 Oct 2004
Kent
Wouldn’t things like wheel bearings be changed in pairs anyway? Well I would anyway.
I don't think it's necessary. I can see that logic with suspension parts like springs, dampers, tyres etc, because their performance may degrade (or at least, change) over time - so suddenly replacing one side with new parts only might cause an imbalance with the worn parts.
But with a bearing, the same doesn't really apply. A bearing wearing out on one side isn't going to effect the performance of the other, nor have a noticeable effect on handling.
