Glorious!LMAO if you thought 6800 performance is bad look at this sucker: 3070 4k Ultra RTX on, no DLSS.
I suspect that is lack of Vram right there. WTF 5 FPS?
It starts at 02:47.
Edit: And btw RTX off, DLSS off, is well under 30.
It starts at 02:47.
Glorious!![]()
That's valid speculation. AMD is supplying:
-XSX
-PS5
-Zen 3
-RDNA 2
(more then likely in that order)
All on one node from TSMC. If true, I would give AMD a pass on availability and just wait it out. It's not like AMD is just in the GPU market selling dies to miners.
The 3070 is weaker than the 2080ti for some reason. Its nothing to do with vram. Not in every game, in legions it should be ahead a few FPS.
If you want to see a beast, look here: 6800xt 8k gaming. Half the price of the 3090 and it does pretty well.2080ti a straight beast ahead of its time
It seems like you do the same shilling on other websites. I hope you get paid for this.The 30 seriers is better placed to do 8k with double the cores, much higher memory bandwidth and DLSS. 8k games really need that and the 6900xt and 6800xt are no suited. The 6000 seriers has half the number of cores and much lower memory bandwidth. With the weak RT of the 6900xt only the 3090 can do 8k and RT with DLSS of course. The video cherry picks its games for the 8k resolution which means its more of less a waste of time. You can do that with any card but the 3090 is the best placed to run 8k @ 60fps.
The 6800xt cant do 8k there is not enough memory bandwidth, also there is not enough shaders. Prue hardware issue. Modern gpu dont have the bandwidth thats why DLSS exist. I mean the shear ignorant here is appalling.It seems like you do the same shilling on other websites. I hope you get paid for this.
@zx128k Who are you trying to convince and what are you trying to prove? All these arguments are so pointless when you can't get any card. How much better value is one against each other is depending on the region you are living. I can't get rtx 3000 cheap where i come for an example, so i bought AMD. I think 6800xt at 720 euro or 640 pounds to make it easier for you it's better than the 850 i would pay for 3070, or 1100 i would pay for 3080, and they are not even in stock, none of them now. And most will not see them for months. So why is it matters what gpu can do (barely) 8k, nobody gives a damn about that, people play at 1080p and 1440p, there is where the big market is, not false dreams like 8k. Not even 4k is a major market.
You’re doing gods work, Lol.All I am doing is nailing ppl here everytime they mislead and post a link the the real facts.
Accuses others of cherrypicking. Calls other people ignorant. Talks about nailing people who are misleading.The 6800xt cant do 8k there is not enough memory bandwidth, also there is not enough shaders. Prue hardware issue. Modern gpu dont have the bandwidth thats why DLSS exist. I mean the shear ignorant here is appalling.
Believes that you can compare shader counts across different architects.
You need more shaders at 8k, no card has the shader count required or memory bandwidth. Like I stated your ignorant. The 3090 can run native is cherry picked games but an AAA game requires DLSS 2.1 with ultra performance mode for upscaling 4k to 8k. That way you can get a playable 60fps. The 6800xt is far worse off at 8k bucause the card lacks the performance. At 8k you are hammering the shaders and the memory bandwidth. Both of which the 6800xt has less of. 8k gaming is upscaled 4k gaming.
"Shaders" are not created equal, you cant compare them 1:1
You are correct in saying that no current GPU can do 8K (even the 3090 cant really do it), but saying that its because "Big Navi has less bandwidth / less shaders" is irrelevant because, at 8K NVidia cards also have the same issues.
HOWEVER .. DLSS is not a silver bullet as :
* It doesn't work on every game
* The performance gains are not consistent across all games that do support it
* IQ issues in some games (mainly blur in motion)
* Vendor locked
Its a very cool technology that I think will end up allowing us to run at these silly high resolutions at OK FPS at some point, but for now being able to render at the native resolution is still the only real option (And for 8K neither side can achieve that today, we have only JUST gotten true 4K playable cards)
