It came up on the MM for £250 so that was the decision point, I already had a 10Gig NIC.
That was a bargain!
How will you securely mount the cards - I assume you only need a cheap/dumb riser as the board should support x8/x8 (and possibly x4/x4/x4/x4?)I could but it's gonna share bandwidth with SATA0, given that MOBO supports 8x8x bifurcation on PCI-E 16x slot I decided to go this route instead, thoughts?
SFP+ connectors cannot auto-negotiate so it will run at whatever options you have on the speed selector or your device. Most are 1GbE or 10GbE but there are chipsets starting to come through that also have the 2.5GbE and 5GbE options. If you have those options then a 10GbE SFP+ RJ45 adapter will let you connect to your motherboard with a standard ethernet cable (preferably CAT6). If you don't then your motherboard will likely run at 1GbE. Or you could add a 10GbE PCIe card or Thunderbolt adapter to the PC (if it has thunderbolt).
So my new NAS is up and running (went the Xpenology route again, I know some won't like that), just copying data across now, the bulk is 13TB which I kicked off at approx 22:00 last night and I'm approx 60% done.
Had a bit of a headache with some mini SAS cable didn’t realise you need SATA (host) to SFF-8463 (target) cable, I just though it’s was all the same so case is still a bit of a mess until those arrive.
I shucked a 3 x 16TB Segate external enclosures, get's you a really nice 16TB EXOS 7200 rpm drive
Interestingly if you put the drive serial number in the tool it show them we their own warranty (not part of a component).
HEADRAT
HEADRAT
I assume that you shucked a Expansion Desktop external drive rather than the Backup Plus Hub ones?I shucked a 3 x 16TB Segate external enclosures, get's you a really nice 16TB EXOS 7200 rpm drive
What kind of price are you paying for these? And are they definitely CMR drives in Exos range, or are some SMR?I shucked a 3 x 16TB Segate external enclosures, get's you a really nice 16TB EXOS 7200 rpm drive
