I wasn't sure where to post this but as Im pretty sure ive found out its a CPU problem Here would be best,
So I've just built a new PC a few days ago and When I load up HUNT showdown the game will sometimes boot and work fine but other times it will crash restart, then load up fine or crash 5 times then load up fine, I've loaded other games on Steam like Mafia Definitive edition and it works fine, until I go to close the game then it crashes when I close it? I can load among us and close among us and its perfectly fine? So idk what the problem is but it seems to cause some problems with bigger games.
I recently played around with my voltages and slightly lowered the clock speed of the cpu to I believe 4ghz or maybe even 3.9 because my temps were getting upto 60 just idle and 90 when just opening a game or running cinebench.
I have a 600w coolermaster gold modular PSU
MSI 5600XT OC MECH GPU
Ryzen 5 3600 CPU
16gb Vengeance Pro RGB DDR4 3200Mhz
I boot windows from my 970 EVO PLUS 500GB
2TB HDD
I just found the error to be this below.
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Cache Hierarchy Error
Processor APIC ID: 12
Any help would be great as I just want to enjoy this new PC instead of fixing 1 problem and another one arising, Thank you.
Ryzen 5 3600 CPU
2TB HDD
