Sure is some very dusty looking Rigs![]()
Mines brand new, cheek.
Gigabyte 3060Ti OC Pro
Comparison to my 1060
Personally think its shameful what ASUS have done with the SKU's and I guess this just proves over what Gibbo was saying.
ASUS have produced new SKU's for the 3xxx series range similar to the existing ones and then started to ship them in low numbers. Meanwhile the original SKU's at launch that people bought, and etailers ordered are still not being fulfilled. So Gibbo was trying to get ASUS to fulfil the original orders saying instead of bringing out new version build the existing ones first and complete the orders.
Just tried the new NVIDIA performance tuning tool. Got +118MHz on my FE.
TomDD
Are you using that Nvidia tool or Afterburner? Or other?Had a go at undervolting, 0.981V, power consumption down by around 10-15% and performance slightly up as it doesn't hit the power limit as much.
Except for Quake II RTX which sits at 1875MHz on the power limit.
Not sure if it is enabled by default. If you go into Geforce Experience -> Settings you should see a tick box which says Enable experimental features. Tick this and I also make sure in-game overlay is enabled. Then pressing Alt+Z and selecting Performance you should see it.I can't find this tool, where is it?
Afterburner.Are you using that Nvidia tool or Afterburner? Or other?
