Water cooled 6900xt will beat the 3090 easily.
Remember the Red Devil had a 3rd power slot on the PCB. So maybe we will see a Liquid Devil 6900xt with 3 power connectors and unlocked power limit.
What about with raytracing
Looks like the AIB partners mean business with their cards check out the specs of this one.
3 x 8 pins power leads, 480W power limit and a 900W PSU recommendation.
https://www.techpowerup.com/275798/powercolor-announces-radeon-rx-6900-xt-red-devil
6900xt ....+120w over reference but only +50w on the PSU? LMAO. 1000w MINIMUM
Fastest 3080 is faster then the fastest 6800xt.
These threads remind me of the multi-month page post wars Matt, Cat and others used to have about Nvidia DX11/FXAA/G-Sync versus Vulkan/MLAA/Freesync back in the day.
But but the AMD card doesn’t have ‘insert tech here’.
What i have learnt is yes AMD might be a bit slower to come to the table on the software side but they tend to arrive in decent shape once the dust settles.
AMD have deep ties to the game development teams and have done for a fair number of years, whatever happens with the AMD version of DLSS/RT it will most likely be in the best interests of the industry as a whole and not just what Nvidia wants to make them money.
Fastest 3080 is on LN2
https://www.tweaktown.com/news/7525...to-2340mhz-breaks-oc-world-records/index.html
If we exclude that one from the TimeSpy results, there is no 3080 faster than the 6800xt. The 6800xt is already ahead on average score and the difference will grow even bigger. It was more than 100 points below the 3080 a week ago. I told you back then that 6800xt will be ahead 3080 in short time.
The reference 6900xt is a bad design that should not exist. 6800xt reference is a great card, the 6900xt is bad since it has the same cooling and the same TDP. But once AIB cards will come, no one knows how fast they will go. Especially since it seems they will have much higher TDP limit.
Don't buy 6800xt if...
You want ray tracing at 4K
Ray tracing performance on the RX 6800 XT is more than sufficient at 1440p, but if you want to turn those shiny graphics effects on at 4K, your money is better spent on an Nvidia card right now.
You play a lot of DirectX12 games
With current drivers, the AMD Radeon RX 6800 XT falls behind when it comes to DX12 performance, and it just so happens that will likely be the API behind most next-gen games.
https://www.kitguru.net/components/graphic-cards/dominic-moass/amd-rx-6800-xt-review/33/As with any new GPU launch, there is a lot to discuss, but above all, raw gaming performance is probably what you are most interested in. Starting first with the 1440p numbers, RX 6800 XT is on average 2% slower than the RTX 3080, it is 23% faster than the RTX 3070 and 21% faster than the RTX 2080 Ti. Compared to the Radeon VII, this RDNA 2 GPU delivers 69% better performance, and that increases to 79% when compared to the RX 5700 XT. Up at 4K, 6800 XT is on average 90% faster than the RX 5700 XT and 23% faster than the RTX 3070. Against the RTX 3080, it is 6% slower at this resolution.
RRP in UK £ kaaapastand?
I think that Asus 6900 XT AIO could be the fastest gaming GPU money can buy.I don't know.
What I do know is I want one, anyone else want to get their hands on one.
That said, I really like the reference 6900 XT design but if you want to unlock the full power of the 6900 XT, you'll need a AIB version.
