How does Zappi know what else is being drawn in the house (leading to a potential overload) inductive loop, voltage drops ?
They attach an energy monitor to your supply and you set it to X amps, normally 100
I agree with you.I'm not convinced a "smart" charger is really that important, my ChargePoint charger is smart but other than looking at the app to see how many kWh I've put in the car for interest I don't think I've used any of the other features!
I thought most cars had built in scheduled charging if you need it?
Octopus Agile does and I’d expect others to do so shortly.I agree with you.
A smart charger would useful if the electricity offpeak tariff time varied daily, but it doesn't. It's always 12am to 5:30am, so EV owners just need to use the onboard car charging scheduler setting to start it.
I agree with you.
Are you guys just plugging straight into a standard three pin plug socket at home then?
Yes I know about the Agile tariffs and the +cost for using them. It's still between 12-5am though@b0rn2sk8 beat me to it but there are tariffs that change overnight as the electricity load varies. If you’re on the right tariff some of these contracts actually pay you to take electricity.
That's all I've done for 4 years. I mostly charge overnight. It's very rare I do more than 50 miles in a day, and if I do I'll be fast charging on the way.Are you guys just plugging straight into a standard three pin plug socket at home then?
Yes I know about the Agile tariffs and the +cost for using them. It's still between 12-5am though![]()
No 13A plug charges at 3kW though, more like 10A so multiply by voltage as we know that varies - this is my dilemma really as Ipace really is a 2.5-3 mile/kWh car. I will struggle to get the charge in time - I have work charging but its 24p/kWh.
Check EDF for some longer periods, but not as cheap.
Most people can get away with just using a 13a plug most of the time. Where you’ll have issues is if you have two fairly long and high mileage days in a row and you have a car with a decently sized battery (say 50+ kWh). You’ll struggle to get the car recharged fully overnight if you plug it in nearly empty.
3kw x 10 hours = 30kw, assuming 4 miles per Kw, that’s 120 miles or about half of of a model 3 SR+ battery pack. If you plug in at 15% it will be back up to 65%ish. There are of course charging losses to account for.
The main benefit of a wall box is that you can push the charge in faster, the cheap overnight rates only normally cover a few hours. You want to maximise your opportunity there. The other is that the car will be fully charged if you plug it in overnight, on a 13a plug, that isn’t guaranteed in anything with a decent sized battery. Less of a problem on cars with smaller packs but you’ll not be going far with those.
Latest PCP quote
Vehicle: Hyundai Ioniq Electric Hatchback 100Kw Premium Se 38Kwh 5Dr Auto (2019 On)
11,000 miles a year.
How's that compare?
How's that compare?
How's that compare? 11,000 is a little generous, it'll probably be nearer 10,000
instant search on hotuk
Fantastic price for this Hyundai Ioniq Electric 100kW Premium 38kWh 5dr Auto - works out at 17.3% of £34.5k P11D based on a 2 year lease with 8k miles with metallic paint. £199.99 per month (6+23 profile), plus £1,199.94 initial payment and £150 admin fee so a total of £5,949.71 - £247.90 net per month.
yes -of courseIt's not the same model
