*** Cyberpunk 2077 ***
Yup 1.04 patch out for PC and Console :D
Code:
Main goal is improvement of performance and stability
Content translation:
[LIST]
[*]Fixed problems with blurriness
[*]Optimization of PC Performance
[*]Optimization of PC Performance with RTX-GPUs
[*]More FPS while driving
[*]Lots of crash fixes on PS4 and PS5
[*]Optimization of Raytracing Performance
[*]Smaller bug fixes and improvements
[*]Flatline-Bugs fixed
[*]Xbox One and Xbox S crashes fixed
[*]Audio, vehicle and vegetation glitch fixes
[*]Missing textures fixed
[/LIST]
Nice!! Increased performance
This game is a stunner. This is an in-game shot having wandered off the beaten track, on my lowly 1080, running 50fps.
I noticed the game folder increased to 100GB+ whilst gog was applying the patch. It's now back to 59.5GB.
ahhh it must be doing something weird with the patch then. I noticed it with the day 1 patch too I needed 50+ gigs when it only used 246mgs ... hmmm got to find something to delete ...
Where did you get the patch notes from?
Reddit - I believe it was sourced from a website that interviewed CDRED
It's taking a good while to properly install! Downloaded it in a flash, took about 5 minutes to install and now it's squeezing it's way up the loading bar "Committing"
The official notes don't mention anything about improved performance only stability?
Well a patch after only a day is certainly an encouraging sign - that's some serious iron will from the dev team after what I'm sure must have been a tough launch too
I would imagine they were all dragged into the office with serious hangovers, huge payout for CDPR yesterday lol.
I have found that DLSS on Balanced / Quality and everything Ultra with RT off seems the best way to play the game
To use RT I have to use DLSS Ultra Perf which kills image quality and makes it not worth it.
They need to work on the Ray Tracing options and maybe add in a Low Ray Trace option with all the bits. Kind of like they did for BFV, it's too taxing for current gen hardware so they should add in a less demanding option.
2080ti here.
Pretty much my findings too (3070). Ray tracing consumes so much image quality and FPS.
