I exchanged Screen Space Reflections for ultra shadows. I actually like how the game looks with SSR off and disabling it means I can maintain 60 FPS nearly all the time at 1440p.
SSR looks bad on anything other than ultra/high but hurts performance too much. SSR on medium/low turns the game into a grainy mess and blurs foreground objects. It seems like they're using tons of SSR to try and mock the look of RT and it tanks the FPS and is not aesthetically pleasing due to all the weird artifacts it introduces to the scenes. There are still plenty of reflections and specularity where they matter when SSR is disabled.
If you're after the fidelity that the benefit from higher resolutions brings you, SSR is hurting more than helping if you have it on medium/low.
Volumetric fog/clouds on low also greatly improves the frame-pacing in busy areas with a lot of smoke, and it's one of the settings that will prevent you from maintaining 60 FPS when there's a lot of action on the screen.
I noticed lower quality as well.Since the ~2GB update i'm now getting some strange graphics glitches in things like smoke from buildings and off the road when doing a wheelspin.
FPS has also improved but visually i'm sure things look worse than before (highest settings, performance DLSS)
I had no problems other than a couple of crashes after loading an autosave before and the game looked fantastic
Only bug I have had is a floating phone on an npc and I'm 16 hours in.
Been trying to get HDR working in game and managed to do so sort of by enabling it on windows first(makes everythingw ashed out on desktop as expected as all the content on desktop windows is none hdr), but when i run the game and set hdr on to any of its HDR settings(there is two) its also washed out!!
https://www.altchar.com/game-news/cyberpunk-2077s-hdr-is-broken-according-to-hdtv-aizaY9M2FuXL#:~:text=It saddens us that HDR,get a satisfactory picture quality.
The article above states the same issue and seems HDR on this game is "fake"
HDR works fine on division 2 by the way.
edit: i also cant get a fps counter to appear via the steam overlay despite setting it. Originally tried fraps and that too wasnt working
I remember someone saying HDR was working though and all i had to do was enable it from windows..Yup HDR is broke, same for next gen consoles too. It does appear like it works but blacks are raised and highlights are somewhat blown out. Vincent from hdtv test confirmed this for consoles.
Most recent patch has broken something for me, had 4 ctd's in 10 minutes. Basically unplayable now. Prior to today I was playing for 4-5+ hours at a time without issue.
The colours are all washed out, it loses its vibrantsIt "works" but it isn't working the way it should and in many ways, it still looks better than SDR but I rather have blacks be "black" than a light grey.
The colours are all washe dout, it loses its vibrants
Get used to at least 1 patch per week for your buggy game chaps! Looking forward to playing the fully fixed version at a discount price next year![]()
Yes, I think they have too. I went re-loaded to a similar scene outside 'Foodscene' where there was a police shootout. Actual FPS was the same but it felt much smoother than before but looked worseIm thinking the patch has lowered graphics in game, so they can give us better fps, not good or right, anyone can make the game run with better performance by lowering graphics quality.
At least it was the best looking game for a few hoursI noticed lower quality as well.
New hotfix to Cyberpunk 2077 is now live on PlayStation consoles and PC. For Xbox systems, we are working to have the update out as soon as possible. Here is the list of changes:
Quests
Gameplay
- Fixed an issue with completing the final objective in Gig: Freedom of the Press.
- Fixed an issue with starting conversation with Johnny at the end in Life During Wartime.
- Corrected a rare issue with NPCs no longer calling V if A Like Supreme quest was abandoned mid-way.
- Fixed an issue with Nix not going into his default state in Spellbound and KOLD MIRAGE.
- Fixed issues blocking progress in I Fought The Law if the quest area is left.
- Fixed inability to find Delamain in Epistrophy.
- Fixed issues related to remaining in the second phase of the quest after finishing Pacifica fight with Ozob if played after Finals.
- Fixed an issue with Nomads no longer present if V leaves the quest area mid-combat in With a Little Help from My Friends/Queen of the Highway.
- Adjusted mappings and re-enabled quest tracker in M'ap Tann Pèlen/I Walk the Line/Transmission.
- Fixed constraints on freedom to get up and sit down if neither blueline condition is met in Violence.
- Fixed issues with time and space resulting from leaving the quest area or abandoning the quest in Following the River.
- Fixed an issue with conversation with Johnny not starting after leaving the hotel in Tapeworm.
- Fixed an issue with quest being blocked upon leaving the quest area before climbing the hill in Following the River.
- Fixed the objective “Go into booth 9” not completing if the room’s entered too fast in Automatic Love.
- Fixed Jackie’s issues with sitting still in The Ripperdoc.
- Other quest fixes
Visual
- Fixed the preview in weapon crafting.
Performance & Stability
- Reduced vehicle appearance pop-in.
- Speeded up switching first person perspective to third person perspective in a vehicle.
- Fixed issues with animations missing from important quest NPCs during cinematics.
Miscellaneous
- Improved stability, including various crash fixes.
PC-specific
- Modified the flashing effect on braindances to reduce the risk of inducing epileptic symptoms. The effect has been smoothed out and the flashes reduced in frequency and magnitude.
- Removed copyrighted songs incorrectly present in the game with "Disable Copyrighted Music" feature toggled on.
- Switching language to default in the in-game settings now correctly sets it to the language of your Steam client.
Im thinking update has disabled some graphics option, or even thou there on high or ultra, there really not now.At least it was the best looking game for a few hours![]()
What a load of dump. Why create a fantastic looks game than switch things off??Im thinking update has disabled some graphics option, or even thou there on high or ultra, there really not now.
