PSU not supplying enough ?
18 Jun 2009
Kent
Having run the 3080 in BFV, the FPS isn't as high as expected. So I ran GPUz in the backlground and saw this
Is my PSU too old ? It's a BeQuiet Dark Power Pro P10 850W but I bought it over 6 years ago.
24 Aug 2013
Lincolnshire
Set to 100% resolution scale in game?
RTX enabled/disabled?
Nvidia control panel > 3d settings > set to prefer optimal power on prefer power management mode?
Idle is probably because you took it out of the game and it isn't being utilised properly.
OP
18 Jun 2009
Kent
Yeah the idle is the alt tab moments
NV control panel is on max performance, playing in DX 11 with RTX off. When I enabled DX12 and RTX FPS wen through the floor
9 Mar 2015
Earth
Whats the clock speed and things like that. Nearly always in GPU-Z you will have a performance limit of some kind (unless you undervolt or something), wil be Pwr, voltage or even thermals acting as a limit to card boosting any further. As above, it will show idle when on desktop etc, or I have found if you undervolt conservatively and limit the frequency manually.
OP
18 Jun 2009
Kent
All at stock. temps are fine peaking at 74c although GPUz says it's pulling 343w !
Now getting all sorts - but all power related
OP
18 Jun 2009
Kent
I think a failing PSU may not be supplying enough juice and causing the card to throttle and therefore lower performance. There’s also the worry of a dodgy PSU in a very expensive box.
Can multiple power warnings in GPUZ be correct. ? Should I get a new one ?
11 Dec 2016
Oxford
"Perfcap rerason: Power" means the card is limiting clock because of board power limits. the PSU is just fine.
In fact jayz2c had a video on this topic just this week
https://www.youtube.com/watch?v=U90bCcPAtMo
9 Mar 2015
Earth
As above, your fine. Your normally always going to have a performance limit, weather its power, voltage temp etc on most instances. Even with a 1.6kw PSU, my 970 shows similar messages
Deleted member 66701
D
Yes, but what PROBLEM are you having? What are the symptoms?
Permabanned
22 Oct 2018
What figure are your getting and are expecting? Where did did you get the "expected" figure from? One thing I have noticed with the 3080 is the % improvement tends to be more game dependent that other series.
16 Aug 2009
You're hitting the cards power limiter nothing to do with the psu if you look at power consumption you'll see its hitting 350W or whatever the limit your card is set to. If you want to increase the power you'll have to raise the power limiter but you may hit another limit i.e. temperature and noise. The other thing you can do is undervolt to lower power consumption and temperature but may reduce clocks/stability. You'll just have to experiment and see.
OP
18 Jun 2009
Kent
I can see this is education week for me. Yes indeed, I'm hitting power limits rather than not enough oomph
Thanks all
