- 28 May 2007
If you read back through the thread this comment was specifically aimed at the new Powercolor Red Devil which lists a minimum system power requirement as 900W whereas the 3090 lists a minimum as 750W. A lot of people will not have a 1000W power supply so would have to invest in that as well.
However the general consensus was that the 6900XT Red Devil will probably run fine on a good quality 750W PSU and almost certainly fine on an 850W so no need to upgrade unless your current PSU is struggling.
Yea but as stated AMD recommend way more than needed. For instance the 6800xt Red Devil recommends a 850w power supply yet uses around 56w less than a 3080 and 82w less than a 3090 under gaming load. The 6900xt Red Devil will most likely use less than a 3080 or around the same.
https://www.techpowerup.com/review/powercolor-radeon-rx-6800-xt-red-devil/29.html
