Greenlizard0 PL & Championship Football Thread ** spoilers ** [15th - 17th Dec 2020]
Have to admit, it looked off to me. Was the angle on Amazon the camera angle the VAR team are using? If so, it wasn't a very accurate angle to use.
Angle shouldn't matter as the lines are calibrated to accommodate it.
They've got to be more consistent with showing us the lines, the speed of that decision only raises more questions on VAR. He looked off from the first replay/freeze.
Don't understand the complaining about the offside. Anything that marginal is either going to **** off one side or the other depending which way it goes. You win some and you lose some. If its that close there is a little bit of luck in it.
This is sort of game I end up getting ****** off with as we have so much of ball etc yet in this case spurs will just sit back and it ends up going wrong for us :(
Because the technology isn't consistently used
We've seen Liverpool goals chalked off after a couple of minutes of video reviews yet that was close and given within seconds.
Because every other week var gives a different answer that's why people get ****** off with it
What would you like to see? You want the decision to take the same amount of time each go? Exactly the same graphic?
What was inconsistent? Did they use the wrong part of the players body?
First half we have done everything we could have against spurs who just don't want to play football.
I belive there goal was offside based on image/angle they showed.
I can't see 2nd half plan changing think it will need to be a wonder goal of sorts to get a win from this.
Williams has done well when he has had to defend.
If needs be yes. If they are using it for Mane against Everton then why not tonight? It isn't consistent.
Because other goals (Salah, Bamford for example) get chalked off after minutes spent with compasses and protractors, whereas that one was just a cursory look and given. Frankly I think today's was done right but it has to be consistent.
They have just shown the offside again and it was pretty clear that he was on. I assume thats why it was a quick decision.
