I switched my 3090FE back to horizontal - it was at least 5 degrees hotter. But I think that the fan setup on the FE is more intended for horizontal flow.
I have a custom loop so may put it under water once a block is released.
Are these pci express riser cable good I was looking at one for my rig .
Get one from a decent manufacturer and you'll be fine. Just remember not to mount your gpu so it's too close to the side of the case or you're going to choke airflowAre these pci express riser cable good I was looking at one for my rig .
How many of you got the 3090 and had a 2080ti?
What one did you get kaap?
Not too bad, seems to run about 8c hotter at load. I'm running the quiet BIOS so with the choked off airflow because of the glass it's averaging about 78c vertically. Would probably be about 70/72c at load horizontally and about the same temps as the reviews. With the performance mode the fan is way more aggressive but it keeps the temps at about 72c vertically, so about 5 to 8c off that horizontally. Fan is much too loud in performance mode vertically so the quiet one is a nice compromise, pretty much the same performance for a slightly warmer card, but it's so much quieter.
It's what I ended up doing, works nicely just be aware if later on you want to use any other pcie slots as your card will block themShould buy one of those cablemod brackets that let's you mount vertically but sets it further into the case so its not humping the glass.
Just FYI that bracket arrived!You raise a good point and is something im aware of with the riser cable. I have a b550 vision D board to put in when my 5900x arrives this
week. I was going to force my pcie to gen 3 in bios, I just don't know if I will get to the bios without plugging card in normally first or whether it just will sit on a black screen.
I love the appearance of the card as I already have enough RGB elements and didn't think I needed more. I've currently got it undervolted to 850mv stable at 1935mhz. Keeps temps between 64-68C on auto fan. Fans are quiet thankfully.
Just a couple of FE 3090s.
Oh only a couple?
It is hard enough trying to get 2 on a motherboard let alone 4.![]()
You can see on the diagram how it hooks into the motherboard.
Nice
 love the names crossed out
 let us know how this beast overclocks / underclocks .
