Would I be able to put the POE injectors in my ground floor media cupboard which will connect to the wall port and then the the internal (cat6) wiring which runs to the 1st floor and 2nd floor will have working POE to run a switch/FlexHD?
Has anyone setup IPv6 on a USG with Zen Internet? I've got an IPv6 public IP on the Zen FritzBox, but i'm struggling to get the USG to get an IP or delegate any to the LAN via DHCPv6.
That's pretty much exactly what I've done. Works perfectly. I think the only Unifi switch you can do this with is the Flex Mini. It's PoE in only. No PoE out.
ThanksSee https://forums.overclockers.co.uk/t...ng-causing-it-can-a-new-router-help.18906926/
There's something on VM (possibly a Hub firmware) that means any UDP traffic passing through completely cripples the service
If possible, I want to use my current plusnet router. Can I go wall socket > plusnet router > ethernet to unifi lite? Is this going to see a decent range increase over the standard router?
Also I was then considering buying a second unifi lite for upstairs. Can this be set up as an access point without a direct ethernet connection?
US-8 is PoE pass-through, PoE powered
All the In-wall access points can do PoE power and PoE pass-through
USW-Flex has all ports PoE power out if powered by the right PoE++ switch.
But I’m not sure if that was the question that was actually asked?
Hi all,
I'm looking to boost the WiFi signal in our house and the Ubiquiti stuff seems to be the best.
I'm not sure where to begin...
Thanks.
The Lite is here now. I ordered one last week and received it a couple of days ago. The LR is still on Pre-Order.You should also be aware that WiFi 6 access points are only weeks away and makes little sense to buy the older WiFi 5 kit if you are starting out now.
To be honest, if the new AP is where your current router is then I don’t think you’ll notice any better coverage. There are laws which limit how powerful the radios are and everything operates within them. Of course the dedicated AP has many more configuration options.
The main advantage of using a dedicated access point is you can place it centrally instead of where the internet comes into your house which is normally in one corner.
The unifi ‘disks’ are also directional, they are designed to be ceiling mounted and project their signal out in a ‘mushroom’ shape. Bad placement can mean worse coverage than a standard omnidirectional router/AP. Ubiquiti have a range of APs for different situations/placements.
You can mesh them wirelessly but the devices connected to the second node will only see half the speed as the other half is used to relay the data back to the main AP. The lite also has a 2x2 antenna which doesn’t have a huge max throughput, once you half it then it’s pretty slow. If you want to go down the mesh route I would recommend getting at least one AP with a 4x4 antenna.
As the above person said you probably don’t need more than 1 AP for a normal sized property IF it’s centrally located. Normally the best place to mount it is on the landing ceiling. You get network up there the easiest way is to run a cable externally from where your internet comes in to the attic.
Ubiquiti is very much ‘prosumer’, if you want something easier then there are plenty of mesh kits available for about £300.
