What kind of undervolts are people running on these?
I've just been playing around with my Gigabyte Gaming OC Pro tonight and have it running 1995mhz on the core @ 943mv - card is on the silent bios and doesn't breach 70 degrees with a fan speed never breaching 65%, quiet and fast so I'm happy (but I have a 3080 due next week!)
I could drop down to stock boost (1770mhz on this card) and try and push even less voltage but seems unnecessary given low temps and noise levels.
Thanks, got my 3060ti FE today and tried your settings to start with. 2010mhz @ 943mv on the default fan profile, max temp was 66c after an hour![]()
A little more playing about today, 2040mhz stable @ 950mv![]()
Can you post your afterburner settings please?
This is on the 3060 Ti FE?![]()
That's my screenshot from yesterday for 2010mhz.
Wack the Memory +1000MHz. It's a no-brainer.
Have you compared any before/after bench scores?
I'm incredibly intrigued. I have Afterburner installed but having not done this before I must admit I am cautious.
Yes, that's what I thought, but just looking at mine with GPU-Z and it says 1980MHz when running the render test. Did I overclock a couple of weeks ago by accident and forget?!Didn't bench it before but the score would have been way lower as the FE only boosts to 1665mhz at stock.
Is the FE better than the Palit? I really dislike where they put the pin connector on the FE.
