Pretty much what you would expect from the circuit vs normal, few seconds for the rubber the rest from the diffs, I mean the would you even fit the Dunlops to your shopping car
At 1280kg for its size it is not lightweight, I think it just has a nice balance to it and the suspension gives you decent confidence to carry some speed, I reckon once you put some good track tyres on its going to be hard to beat on a small track.
Would take the same alloys as my MX5 too, which is making some wedsports very appealling right now, I was considering going cheaper with some Bolas but if I go for the Yaris I can talk myself into it, both are lighter than stock at 0.7-1.2kg a wheel, I just couldn't put less than et45 on the Mazda without a big pull for 255s, in fact I have just been asking bola if they'd do a 47 so I could limit body mods to just flat arches but you would not want that offset on the yaris
I'd be fine with a tuning box, ran one for a long time on my Abarth and although it did blow turbo at the Nordshcliefe, I had turned it up to max and it was a long time a max boost there compared to anywhere else, when you consider the bodge it was in my case remap + box to get around limits taking it to ~ 230bhp I had it coming as a sensible man would have fitted at the very least a stuffed turbo, not me
Tuning box without exhaust is doing 307, dte put a youtube up already I thought I posted it here.
Just let me confirm I am readin that right, you had your Abarth remapped, and then you added a tuning box to push it even further beyond the remap?
	That is good seems a tuning box with bolt-ons be good for 315-320 then, solid 50 over the stock dynos and I suspect a proper remap with bolt-ons be 330ish, maybe 350 top. Then bigger turbo time!
So managed to find the dyno from the OCuk powerstation dyno days which show the first few stages of progression stock, remap and remap + tmc box on 5, I ended up running this higher which probably lead to my issues, fuelling was fine, final before I put my car back to stock was something like 230bhp and 270lbs torque, which is plenty in a ~1135kg shopping trolly, so if you fancy more from your Abarth it does do something, key thing is fuel quality with these, they aggressively pull timing
DTE show the Yaris dynoing at the figures the exhaust guys are getting stock, also shows where the plugs are.
 ) box came off when I retired it from motorsports in favour of the Mazda mind you but had done a good 60k on it.
 I  have taken many scalps though
I'm.not surprised that a lighter car with good power and adaptable 4wd can beat a fwd hot hatches or a 25 year old celica weighing about 200kg more and having less bhp
There is a guy who races Celica's in some classic 90's racing series and does 1:15 laps round castle combe. (You would expect Plato to be even quicker) The Celica they used in the video was an original press car (JC tested it back in the day) and pretty standard. Something resto modded would be a lot more honest.
