Good morning, thank you @Sumanji
Ok, thank you as well Shiari - maybe i give it a try without the original backplate if i can mount it properly with the screws from Bykski.
If somebody else has experience with the nitro backplates or the byski cooler - input is very welcome.
I found some reddit thread over Bykski Vega Fullcover Users who had problems with the right fit of GPU blocks and extremely high hot spot temperatures, but some of them used the thermal pads wrong and did put them on the wrong components. Any experience here too?!
Best regards
facet
Best regards
facet
