- 18 Oct 2002
- Eltham
The black screen is what I had during benchmarks but then resolved itself (or seemingly so) once I plugged in my second cable as I was half asleep when setting it up (card has 3 pins)
Maybe try running two separate cables instead of the splitter if that's what you're doing?
I'm using two separate cables, what PSU are you using?
I would have thought the 850w Seasonic I'm using would be plenty at stock but I notice on the LTT video they mention they had problems with a 1000w Seasonic tripping using a 6900 XT.
