I don't see any reason why it shouldn't work, usually you will have to disable any battery optimisations the phone might have on Fitbit's app to get it fully working. Seeing as you already have the Poco, have you tried it with that phone yet? Or is there a reason you want to use the Versa 2 with a different phone?This is getting painful now. I managed to confirm that people had the Honor 10 working successfully with the Versa 2 (changed from a Versa 3). Bought the Versa 2 and now the sodding Honor 10 has packed in.
Can anybody recommend a £200 mid range Android that they have managed to get working with a Versa 2. If you go on the Fitbit forums a mod jumps in straight away and points you to the list of approved phones, all of which are quite old. I have a Poco X3 at the moment and that would be the sort pf phone I'm looking at, but I've read elsewhere that there are issues with the Versa 2.
Any help much appreciated
