Iiyama GB3461WQSU-B1 - Flat 34" 1440 144HZ 1MS IPS Freesync for <£400
Caporegime
OP
4 Jun 2009
Anyone using a nvidia card with this screen? Preferably an ampere one..... Does free/g sync work ok?
So tempted to get this but its just too wide been umming and arrring for few days but then reading this thread sounds like its another lottery monitor.
Since the latest firmware I don't think many have had any issues, just so happens most of the votes and posts in this thread about faults was to do with the old firmware.
7 Mar 2005
I've not actually tried many different games since switching to the 3070. Horizon Zero Dawn benched an average of 97 FPS at alsmost maxed settings and ran beautifully. Currently playing AC Valhalla (not the best example) which with a few adjustments tends to run at 70-80FPS with occasional dips to ~62. The Mrs is playing RDR2 pretty much maxed wich ranges from ~45-70 FPS, but there's huge scope for tweating there without losing much detail.
For reference my previous GPU was a 2070 Super (very close to the 1080Ti), and have generally observed around a 30% gain at 3440x1440.
28 Oct 2009
Dark Side of the Moon
30% AVE is pretty good. Just need a 3070 to come into stock.
Thanks for the input.
Caporegime
8 Nov 2008
Just caught sight of this and I'm very tempted. One bonus is that it isn't curved.
One minute I was going with ultrawide then I started inclining towards a 32" 16:9 1440p.
Choosing a monitor is an agonising process. :D
Another which has me interested is the Acer XV340CK. A bit dearer but still looks to be good for the money.
31 Dec 2007
The TARDIS, Wakefield, UK
I`m agonising like mad had my pointer over the buy button loads of times. Its just about 8-10cm too wide. If there was a decent 32" 16:9 1440p 144mhz I would get it.
(btw I`m already on 32" 1440p 75mhz and best monitor I ever bought just wondering whether to get something better to let the 3080 run free)
Well Acer's QC is superior to Iiyama's imo. However the cheapest I've seen the XV340CK was still 170 quid over the cheapest I've seen the GB3461, so...
Iiyama's QC must be very very bad as Acer's is appalling.
28 Oct 2009
On the flip, mine is fine and replaced a good Acer. I think I'm lucky of can't stop faults.
Caporegime
8 Nov 2008
I'm currently only considering 32" flat screens as the extra horsepower required to drive a 3440x1440 screen would most likely leave me a smaller choice of video cards, ~ RTX380 or 6800XT.
I think I'd rather get a screen where a wider range of cards can deliver consistently higher FPS, hence staying with the 16:9 1440p.
That could, of course, change. :D
31 Dec 2007
Yeah but problem is there are no decent flat 144mhz 32" screens.
trouble is I just know if I get one it will have an issue just dont know whether I can be bothered with the return rigmarole. I was very lucky with my AOC its near perfect and its probably longest I've had one monitor. (went through 3 or 4 different ones a year or so or more)
