3080 and 3070 rumoured for released in January https://www.pcgamer.com/uk/nvidia-rtx-3080-lands-in-january/
This is great. Will be a beast and big step up compared to mobile GPUs of the past. Looking likely to be the first one to be faster than the fastest desktop cards of the previous gen.
Here are some benchmarks https://videocardz.com/newz/nvidia-...irmed-with-6144-cuda-cores-and-16gb-of-memoryThe rumoured 3070 mobile looks to be closest to its desktop counterpart. That’s the one I’m hoping to get hold of.
The 3080 mobile is rumoured to only have a few more cores than the 3070 mobile.
Hopefully supply is less of an issues for the RTX 30 series chips when they launch in laptops.
I’m assuming Spring before we see the laptops on the (virtual) shelves.should I hold off buying the 2080 Razer Blade 15?
I would like a laptop soonish and am unsure if Ill be left waiting due to no stock similar to desktop cards when the new mobile 30x GPUs come out.
The equivalent at the moment will be the 2060 and those sit in the £1100 to 1600 range.I'm in the midst of building a £1200 PC. I'm guessing a 3060Ti laptop will cost more than that?
Seems like a lot of the current listed 2021 laptops are 10th gen intel. Only Asus is mentioned to be Ryzen. Although it’s early days.
For me it’s possibly between Asus and Gigabyte, but if Gigabyte don’t offer Ryzen then I’m probably going Asus.
