Black Ops Cold War is using 8.4 to 8.5GB on my 3080Congratz. How have you been coping with only 10GB VRAM so far?![]()
That cannot be right. One guys said it was using 18gb or somethingBlack Ops Cold War is using 8.4 to 8.5GB on my 3080
Is this where all the GPU`s have gone ?
https://www.bloomberg.com/news/phot...currency-mining-comes-to-arctic-circle-photos
I was tempted by a 3090, but instead I've just ordered a 49" ultrawide. Now I'll be patient and get a 3080FE next drop....all for only a little more than a 3090....definitely the better value option!
you talk as if its easy to get these on drops.
People are replacing thermal pads themselves. I would guess, maybe erroneously, that with a 3080FE the cooling might be even worse/cheaper than the AIB boards..therefore worse for mining?
Not sure the major companies will be rushing to get back into the mining-focused market. They all did that last time, then the bubble went pop and there seemed to be tons of stock of mining-focused motherboards and graphics cards left over that nobody wanted. I think ASRock only got into the graphics card business because of the last bubble, which popped just as they started releasing cards, but I guess that's paid off for them in the long run.I really hope NV decides to produce mining GPUs in large quantities, that should help everyone if they can arrange a separate production deal from TSMC or maybe samsung.
I think there's an arguement for AMD and NV to produce mining GPUs all year round, if it helps to keep prices affordable for gamers.
That sucks. I listened to the recording and couldn't hear anything but that might be coz I'm old now and according to youtube have the hearing of a 43 year old, which is close enoughCan't believe it. My replace 3070 FE arrived today and it has the exact same issue. (Sound of hiss from last time)
At this point I can only conclude there's an issue with this batch of graphics cards to the retailer.
Consider me completely alienated from Nvidia Founders Editions at this point; I might as well buy a scalped 3070 and sell this on.
(Or ofcourse, I'd be open to simply replacing the fan when third party options become available).
I assume you tested to check its definitely coming from the graphics card and not the PSU. If I can't hear your recording it could be my 3070 FE has horrible high pitch whine, I just cant hear it! If you were the unscrupulous type you could sell it even with the mention of coil whine or just no refund policy... I must rewatch that film The Ninth Gate.. I think it all works out if I remember correctly..
I've double-checked my 3060 Ti FE. Nothing like this sound, the card is almost silent. And under heavy load it sounds like a very quite "hum".
Try testing your 3070 FE in different computer with different PSU, just in case. Maybe it is not the card itself, but something else.
It's possible I'm just a bit OCD about these sorts of things but I just don't want to hear a hiss noise whilst waiting for my GPU to hit 0% fan speed (takes a while with current drivers).
Anyway, I think I'm just going to get another 3070 (probably the Gigabyte one) and sell the FE since insane people are spending £650+ on these.
I'll post any updates from Nvidia or the retailer.
Even CeX will give you £561 cash for it if you want to sell it quickly and hassle-free, so sending it back for a refund would be pointless.It's possible I'm just a bit OCD about these sorts of things but I just don't want to hear a hiss noise whilst waiting for my GPU to hit 0% fan speed (takes a while with current drivers).
