*** Big Fat Weight Loss Thread ***
Yeah if you have a high sodium diet, which most unhealthy diets are, just consuming less salt can make you lose a fair amount of weight so first week can see quite a big change like I did in the beginning.
Even now if I have a junk food day, I can put on a lot of "weight" the next day which will then also disappear the day after as it's just extra water weight that comes with all the sodium.
This is why I don't bother weighing myself daily if I know I stuck to my calories and just look at my weekly trend.
I like the look of those tights but although my legs are slim, I'm 61 (a young looking 61 mind :p) and I think those tights are for you younger folk.
This is why those of us with modesty still put shorts over our compression layers :p
Well I just tried the joggers on and I have to say I'm really pleased with them. They're slim fit, no ugly baginess, and they fit and look and great with the new trainers. I also tried the long johns underneath the joggers and they also look good and are skin tight. Walked outside to test warmth and they keep my legs perfectly warm so I'm looking forward to my first jog. I could probably run with just the long john's and I could have bought tights after all. :p
Re your phone remember you'll be getting sweaty and or wet in the rain and you want a pouch you can position in non sweaty areas to limit moisture to the unit and chafing to you. You also want easy operation of the unit without getting it out and where the cord can reach your ears without awkward snagging of the cord (unless you've gone all WiFi Bluetooth in which case how good are your earphones bus at staying in?)
Yeah, I'm considering buying some recommended wireless buds that I believe stay in the ears securely while jogging. I think the best option might be a thin stretchy runners phone belt underneath my jogging top to hold the belt. I wonder if anyone here can recommend a good one that doesn't bounce around too much.
I have this one and it's pretty good. The only problem I sometimes have is finding the entrance into the flaps! It has one big pouch at the front middle for your phone and a small pouch either side, for keys.
I have relatively big ear wholes (I think) and have tested probably between 4 and 10 different totally wireless earbuds and none have ever fallen out while running, so you should be fine. I think a bigger issue is some make your steps echo around your head. I guess some make a really tight seal in your ear, it's a bit like if you plugged your ears and are something. You hear all the movement of your bones.
I have this one, (https://www.salomon.com/en-gb/shop-emea/product/pulse-belt.html#color=21389) but if i'm honest, i'd just stick with your pocket for now. If the joggers are slim then they shouldn't have huge pockets which would cause it to bounce around too much. If i run with my phone i'll just stick it in my pocket and in most of my shorts it's not too bad. You only really need to use it once to set the activity and then again at the end.
Maybe then if you decide you really enjoy running you can then start spending more on things :)
For headphones i have these which are great, however they're one of those items that're usually in some kind of sale (not at the moment sadly), and i think i paid around £18
https://www.amazon.co.uk/Soundcore-...pirit+x&qid=1611131917&sr=8-3&tag=googhydr-21
I much prefer the ones that hook over the ear for running, although be warned that if your hat is a tight fit it can be uncomfortable as it can really push the buds into your ears. I tend to wear my hat just above my ears now because of it.
Been taking my cut a bit more stringently since Saturday. Even though lost 8-9 pounds since April last year. That's mostly been due to weight training and better quality of food. But belly is still there, so now am targeting 2700 calories per day.
Meal prep is the hardest, when nothing is made it leads to temptation...
shifting the belly is a pain. I've still got mine too. I can't wait to get further with the decorating and DIY to get the boxes out of the lounge so I can start doing crunches and situps watching MOTD again. It's a great way to make the exercise seem easier.
Guess it depends on your circumstances with family etc. But we make up a tea schedule over 4 weeks and stick to that. Generally meals which are easy to make and freeze well etc.
We then buy our shopping online in especially and so always have food in for our meals, so don't need those quick little trip to the shops where you end up being tempted.
We do the same. It definitely helps.
I find the problem is, if you're looking to keep size/bulk but lose the belly, they kinda work in opposite of each other. To lose the belly, you probably should drop the cals lower than that (IMO of course :) ) but then it means you don't have the cals for the weights. I had to accept I would get smaller as well as lose fat.
Just remember, abs exercises are not how you lose a belly though :)
head. Popped. WHAAAT?
Yup that's the truth Andy we don't wanna loose our gains.
But think I have finally come to terms the muscle will look better when its leaner I hope.
Right now it only looks good when pumped lol.
Thank you Andy. Looks pretty good. I don't know how much it matters as it would be underneath my jogging top, but that belt doesn't have any zip so does it feel like the phone or keys could jump out while running?
Thanks Martyn. I'll try the phone in my jogger pockets as they are a slim fit but I suspect it'll weigh the joggers down. And the buds I think I'm buying are about £40 (Boltune BT-BH024) as I don't think I'd get enjoyable sound quality for less.
I was going to buy a Wahoo heart rate monitor chest belt, but I'd really much prefer a watch that shows heart bpm, calories burnt, my running speed and distance I've covered all at a glance. Much easier to see than taking my phone out while running. Does anyone here use one and do you find it accurate enough? And which watch? I believe apple have the most accurate but since I use an android phone I don't suppose it's compatible. Fitbit?
The soundcore ones are fairly decent, to be honest, when you're out running and have all the background noise you don't really notice any nuances in the music anyway, it's more just there as background music.
A chest strap would be more accurate than a watch, however this is generally for interval based workouts. A watch can have delays in readings so i'll find i can finish a sprint and it's around 30 seconds later that it shows the increased HR, a chest strap will be more accurate and responsive, but for a base reading a watch is fine and as you say has all the extra benefits that come with a watch.
I have a Garmin Fenix 6X Pro, but obviously there's no need to spend that much! I'm not sure about an Apple Watch being most accurate, i had one prior to this, and would often get different distance readings on the same route, something which doesn't happen with Garmin.
Depending on budget, something like the Garmin Forerunner 245 would be a good option. You can also get a music version so no need to carry a phone at all.
No chance. As I say, it can be hard getting in sometimes to get the things out, let alone them coming out when you don't expect it! :)
Not sure if you're being sarcastic, as I feel like it's fairly well know, hence the smiley. Sorry if I'm stating the obvious, just thought I would check :)
As @Martynt74 says above, Garmin are considered a safe go to for a running watch. I have the 735XT and it cost me less than £200 if that's any good?
no not being sarcastic, I've been doing sit-ups to try and get thinner, am I wasting my time? (or should that be "waisting"?)
Unless you're doing 1000 a day (assuming no other cardio) then yes. There are far more effective ways of burning calories than sit ups.
