Isn't that a lot to be losing in a week!?!
I thought 0.5/1kg or so was about 'normal'
I suspect most was water weight (currently 115 kilos at 6ft). I lost a kilo last week so more in line with the expected.
I like the look of those tights but although my legs are slim, I'm 61 (a young looking 61 mind) and I think those tights are for you younger folk.
This is why those of us with modesty still put shorts over our compression layers![]()
Re your phone remember you'll be getting sweaty and or wet in the rain and you want a pouch you can position in non sweaty areas to limit moisture to the unit and chafing to you. You also want easy operation of the unit without getting it out and where the cord can reach your ears without awkward snagging of the cord (unless you've gone all WiFi Bluetooth in which case how good are your earphones bus at staying in?)
I wonder if anyone here can recommend a good one that doesn't bounce around too much.
Been taking my cut a bit more stringently since Saturday. Even though lost 8-9 pounds since April last year. That's mostly been due to weight training and better quality of food. But belly is still there, so now am targeting 2700 calories per day.
Meal prep is the hardest, when nothing is made it leads to temptation...
We do the same. It definitely helps.Guess it depends on your circumstances with family etc. But we make up a tea schedule over 4 weeks and stick to that. Generally meals which are easy to make and freeze well etc.
We then buy our shopping online in especially and so always have food in for our meals, so don't need those quick little trip to the shops where you end up being tempted.
) but then it means you don't have the cals for the weights. I had to accept I would get smaller as well as lose fat.I can't wait to get further with the decorating and DIY to get the boxes out of the lounge so I can start doing crunches and situps watching MOTD again.
I find the problem is, if you're looking to keep size/bulk but lose the belly, they kinda work in opposite of each other. To lose the belly, you probably should drop the cals lower than that (IMO of course) but then it means you don't have the cals for the weights. I had to accept I would get smaller as well as lose fat.
Just remember, abs exercises are not how you lose a belly though![]()
Thank you Andy. Looks pretty good. I don't know how much it matters as it would be underneath my jogging top, but that belt doesn't have any zip so does it feel like the phone or keys could jump out while running?I have this one and it's pretty good. The only problem I sometimes have is finding the entrance into the flaps! It has one big pouch at the front middle for your phone and a small pouch either side, for keys.
I have this one, (https://www.salomon.com/en-gb/shop-emea/product/pulse-belt.html#color=21389) but if i'm honest, i'd just stick with your pocket for now. If the joggers are slim then they shouldn't have huge pockets which would cause it to bounce around too much. If i run with my phone i'll just stick it in my pocket and in most of my shorts it's not too bad. You only really need to use it once to set the activity and then again at the end.
Maybe then if you decide you really enjoy running you can then start spending more on things
For headphones i have these which are great, however they're one of those items that're usually in some kind of sale (not at the moment sadly), and i think i paid around £18
https://www.amazon.co.uk/Soundcore-...pirit+x&qid=1611131917&sr=8-3&tag=googhydr-21
I much prefer the ones that hook over the ear for running, although be warned that if your hat is a tight fit it can be uncomfortable as it can really push the buds into your ears. I tend to wear my hat just above my ears now because of it.
head. Popped. WHAAAT?
I believe apple have the most accurate but since I use an android phone I don't suppose it's compatible. Fitbit?
no not being sarcastic, I've been doing sit-ups to try and get thinner, am I wasting my time? (or should that be "waisting"?)
