The Radeon RX 6900/6950 XT Owners Thread.
12 Feb 2004
Stoke
Hey got one arriving tomorrow , the power colour version !
do you think i will notice a difference to the RX480 im limping along with now ?
12 Feb 2004
Stoke
MBA or Red Ddevil?
You should notice a massive increase in perf, biblical proportions. I hope you have a decent CPU. :)
It’s the MBA I believe, stock Radeon cooler , I’m mounting it vertical and don’t have a lot of clearance to the glass door on my case.
I did have a 5700xt but sold it on a while back but then missed out on getting a 6800xt on release and managed to pick up a 6900xt yesterday instead.
I’m using a 5900x cpu so should work well ?
Caporegime
12 Jul 2007
United Kingdom
Ah nice, yuoi'll be golden then. Enable SAM in the BIOS too if you have not already. :)
Man of Honour
30 Oct 2002
Surrey
Anyone know what this ARES keyboard in device manager is that arrived with the 6900XT?
Seems like ever since I installed my 6900XT my bluetooth keyboard has been playing up.
Could be coincidence but hmm..
Latest drivers BTW 20.12.2
Caporegime
12 Jul 2007
United Kingdom
Hi all my 6900xt is heating up to 80c at 90-80% utilisation is this normal? My 5600x is at 70.
Probably, but would need more information.
  1. What 6900 XT are you using? AIB or MBA?
  2. What temperature is hitting 80c, Edge or Junction?
  3. List every change you made, if any, under Radeon Software > GPU Tuning?
  4. What case are you using and what is your airflow configuration (intake vs exhaust)?
  5. What game/benchmark are you running?
4 Aug 2011
6900 XT Red Devil Limited Edition
WOW, that system looks good! And I hope you enjoy it.
I have honestly never had the guts to water-cool any of my systems over the years.
Do you mind me asking, what configuration do you have, for the push-pull of the fans, on the two 360mm radiators?
I was hoping the latest drivers would help, with my monitor issues, but no joy yet.
On the plus side, Hitman3 performs better.
21 Jun 2006
UK
Thank you mate, I've been through a lot of GPU's to finally settle on this.
Full build is:
Lian Li PCO11D
Aorus X570 Master
Ryzen 5900X
32 GB Trizent Z Neo 3600 CL 16
6900 XT Red Devil LE
3 x 1TB NVME
1200W Asus ROG Thor PSU
1 x TX360 slim rad on the bottom
1 x EK PE360 on top.
1 x EK XE360 externally mounted (black hose on top of distro).
6 x Corsair QL120 on internal rads.
6 x EK Vardar on the External rad.
EK Velocity CPU Block
EK distro ( pump uograded)
Barrow hard and soft tube fittings.
21 Jun 2006
UK
Lovely looking build. :)
Still amazed that you sold your 6900 XT then bought it back again when you already had a 3090!
To be honest, the 6900 XT is considerably cheaper (£1150 ) than the 3090 Xtreme (£1820) and to be honest in the games I play its faster too.
It runs around 2700MHZ no problem, it does get hot though.
GPU block awaiting delivery.
Caporegime
12 Jul 2007
United Kingdom
Nice. Would be good to see some Firestrike and Timespy benches from your system.
