Another xr7 to go in the bottom for gpu which will be push pull, FLT 240 below the 120, tubing sorted, cables sorted, lighting sorted (will try uv with the mystic fog, otherwise will jist use neon, or clear)
Yeah, I'd rather have dual loop tbh, and d5's.
The front distro on the XL is a D5 though at least.
Untitled by mikehhhhhhh, on Flickr
Untitled by mikehhhhhhh, on FlickrThanks for all the advice. My O11D arrived today and I was pleased to find there is no concern with cables pressing against glass.
One massive disappointment was the orientation of my fancy RGB intake fans. I'd never even considered the orientation of them, I just assumed they'd be orientated for intake.
I think I’d like to add custom water cooling at some point.
I’ll wait until the gpu block is out and I can buy it all together and have it shipped quickly, though. I only do things impulsively
After a lot of thought the past few days I think I’ve landed on the decision to buy a O11D XL and go with a front Distro loop. But then again, the way I’m going I’ll probably change my mind in the next weekI did give serous consideration the meshify XL. that is a beast of a case.
Damn that’s close!Thanks for all the advice. My O11D arrived today and I was pleased to find there is no concern with cables pressing against glass.
Currently running an O11D with 360mm aio top mounted with side/bottom as intake fans.
Would it be worth while side mounting the aio? The 5800x is quite toasty.
Damn that’s close!
Unfortunately it looks like the custom cables I plan to get would definitely not fit that so XL it is for me!
one thing you might want to experiment with is making the fans go on the opposite side of the case (inside the main area) to see if that looks any better with the lighting. Might have an effect on thermals too.
when I had my O11D I tried both orientations and ended up keeping them inside the main larger area as it just looked more appealing.
Unfortunately The only photos I have are of my old pc build in the case before I switched the fans to the opposite side for my newer 3900x build.I thought about it, but I think there's headroom in the cooling for the CPU but the GPU is very much thermally limited, which is evident by the improvement in performance that came with the improvement to airflow.
Do you have any pictures? I just liked the idea of keeping them out of the main case space.
New Case by Simon Hipsey
Looks great!
What type of loop you planning?New Case by Simon Hipsey
So managed to get the build moved over to the new case.
Ended up having some issues, one of my ARGB headers for some reason on my MB isnt working so everything is a bit sloppy right now but going to tidy it all up next weekend along with some of the cable managment when my new hub arrives. Have one more strip to add to the top of the case and new ram coming tomorrow.
Will hold me over till I do a new loop in March/April.
