What type of loop you planning?
Im thinking of doing a front distro in the XL white version with a White 360 rad in the top and all Lian Li Uni SL120 fans.
then down the line, if I am confident enough to take apart a 3090 FE, I’ll put another 360 in the bottom and get one of those nice ek FE blocks
So I already have a GPU block on order with EK so it is def going in there. From what I've seen pretty confident with taking apart the FE, seems less faff than a Titan X which was the last one I had a block on.
Overall the loop will be a relatively cookie cutter 011 build, was going to go with the side distro but as it is a DDC pump I am either going to go with the front distro or as I am actually goign to go matte black soft tubing I am go with the FLK 360 pump res on the side as they come with a D5
Regardless it will be an XE on the bottom and standard 360 on the top. Also toying with the idea dual loop with 2x 120 FLTs . Fan wise I like the Uni fans but I have always struggled to see where they land for static pressure. Legit this is the first time I've even had RGB but given the monoblock/distro & GPU are all going to have it I am toying with it a bit more. So I may go with Noctua Chromax fans with the white accents like I've done now and keep the black and white minimilist build which I think will look nice with the matte black soft tubing especialy if I get my cuts nice and tight so it's tidy.
Not rushing as promised the Missus we would move before I did another loop.
