Managed to get my FE to hold steady at 825mV at 1890MHz, then a 500MHz overclock on the memory. Temps sit at around 63 degrees in my O11D, bloody well chuffed with that. Looped Port Royal for a couple of hours, Heaven and then had a long session on COD last night.
Is anyone able to work out what saving I'd be getting in terms of power draw? Not that it matters but it would be interesting to know
easily be able to tell for yourself. MSI AB / GPU-Z all have powerdraw numbers. MSI AB / Rivatuner even lets you set up power draw on the On screen display ingame. Set at stock see what you hit and apply the undervolt and see where you land. I expect compared to stock will likely see about 80w+ reduction
Some games will pull more power then others. COD is not too bad, but same undervolt in control / Cyberpunk 2077 will see a higher power draw as card can still pull more power if needed.
