Very nice.
I bet you wish you went larger than 32"![]()
Levelled up on the old sounds.
Decided against a soundbar and went with The Fives by Klipsch.
that looks awesomehow do they sound?
@Howard That's a tight fit for your amp/receivergot lucky there.
Loving the clean yet high-spec look of that setup (minus the ancient Tivo box I guess)!
Can that Xbox be laid on its side? Its form factor looks rather ungainly and won't fit well in most cabinets otherwise!
It looks a bit like Michael Scott’s TV in that photo but in reality it suits the space perfectly![]()
What stands are you using for the Fives?Thanks Howard.
The TiVo box is just for show ha, like the rest of what's on the shelves. All streaming and USB input nowadays.
Yes the Series X is an odd size. I can hide it behind the TV, not sure if I will yet.
Comprehensive review below on the Klipsch speakers if anyone wants to know more.
Cheers for the link, they look great considering the price.They're stools I bought from Amazon minus the tops.
https://www.amazon.co.uk/dp/B01BQCC...abc_PH2PYYE6EE7PT38Q66WV?_encoding=UTF8&psc=1
