Shadow of the Tomb Raider Bench Thread
DX12
1080P
8700k 5GHZ
RX 6900 XT 2725core2100mem
21.1.1
1440p
1080p
I find this is difficult bench as there are so many variants. Are we to use SMAA4x or other? In above SMAA4x is used, initial post does not include display settings
I find this is difficult bench as there are so many variants. Are we to use SMAA4x or other? In above SMAA4x is used, initial post does not include display settings[/
It's once you change Screen space contact shadows to high its changes preset from highest to custom.
I guess its down to trust.
DX12
1920x1080
5800X @ stock + 75Mhz max overclock boost, -20 on all cores Curve Optimizer
RX 6900 XT 2700 / 2150
21.12.2
DX12
3440x1440
21.12.2
@heartburnron tbh we really lack 1080p and 1440p data for the new cards. I would appreciate at least a 1440p run if you have the time.
I will run some 1080P and 1440P runs when i have the game downloaded. From memory i think i got 145FPS or thereabouts at 1080P using the settings in the OP.
