Thanks - that's similar to the gold one I used - great once there.was a hole but wouldn't fancy starting off with that - there would be striations all over the wall lol
I’ve not got anything like that unfortunately.
It’s probably like 55mm long by 20mm wide. It’s just to fit around some cupboards.
My circular saw has a spacer bar. You set the board up with a clamped batten/straight edge offset to one side of the cut line and use the guide to follow that edge so your cut stays straight. NB to position all your support tables/trestles etc to be out of the way of the blade when goes through the sheet!Does anyone have tips for cutting boards straight? I've got a jigsaw or circular saw at my disposal, but feel like cutting by hand 2.4m will not be straight at all. Dumb question, can a sliding mitre saw cut things sideways (turn the saw 90 degrees from usual position) and you slide the board through?
I've also done long cuts with a jigsaw. Getting the setting right for the material in terms of speed and any rocking motion (as well as using the right type of blade!) will help. Draw a pencil line the whole way and follow it methodically without rushing and with practice you can get good clean straight edges from your cut. It's a lot easier in thicker board than thinner (<6mm) stuff which starts to try and bounce/flex a bit too much and where a circular saw does better IMO.
Incoming man job for the weekend - put this up
As others have said, clamp a spare bit of wood on as a guide.Does anyone have tips for cutting boards straight? I've got a jigsaw or circular saw at my disposal, but feel like cutting by hand 2.4m will not be straight at all. Dumb question, can a sliding mitre saw cut things sideways (turn the saw 90 degrees from usual position) and you slide the board through?
We put up a Keter shed last weekend, was pretty easy, just make sure you have a cordless drill/screwdriver, there's LOTS of screws and it would have been a nightmare doing them all by hand.
Any recommendations for a decent home DIY kit?
Looks nice, after all the issues I've had I wish I didn't have a wooden shed. Not to mention the time spent painting the bloody thin. Also the case looks goodPut a few frames up
New fixing in place for the new Fiskars and two new fixings to straighten up the DeWalt case
Then outside to put up the shed in a bag
Started off with the plastic grid base to raise it up a bit. Although it's composite we.do still bet some standing water there. Will also allow me to move the whole thing relatively easily until we are happy with the postion and orientation. Will fix the whole thing down once we settle on final location.
Shed base on top
Sides and back up
"Gables"
Roof
Door and window
And done !
