Ive decided after some deliberation (and discussion with a colleague with an i3 who does this) to keep the charger portable, and just chuck a 16A commando onto the existing feed at my garage. This will vary for everyone but the route to get 32A out there is just too hard to consider for me at the moment, as my CU is central to my recently renovated house.Been convinced to try an EV so should be picking up my new toy on Monday, a used 120Ah i3.
Any advice on preparing for and owning? I was going to look at Podpoint for the wall charger and see they have a few options (kw) and tethered or untethered options. If I get untethered I assume I just use the BMW cable provided? the car comes with a 3 pin cable and 11kw public charge cable. Or is it better to get go with Tethered?
I assume most change to an EV friendly energy tariff? With Bulb still at the moment and saw something recently about them coming up with a new tariff soon for EV owners.
https://evonestop.co.uk/products/type-2-portable-mode-2-16amp-commando-3pin-evse-charger-10a-16a-5m
Quite an easy option as you can just run this off existing, and also means that you can move the charger easily between locations should you so wish.
They also do 32A chargers like this too, obviously requiring a 32A commando and circuit though.
