Miners have already got hold of some 3060s from what I seen on Reddit.
Says it all really, even getting them before they're on sale. What chance have actual gamers got while this **** show continues?
Yea okay, they said it may restart by the "end of the week" .. so I expected some message from them by end of the week... it been like 5 weeks since... and almost a month since I asked that here ...I think this answers your question...
Temps are probably fine unless you're planning to mine with it.Hi
I am loving my 3090FE despite initially having buyers remorse getting it. (I got fed up going for a 3080 sensibly priced)
Has anyone taken the backplate off and replaced the thermal pads on it to get the memory temps down a bit. I am worried at how hot the ram on the back is. Such a shame as the rest of the card so super cool. Igor's lab did something with a 3080 but the 3090 has more ram. I am a follower not a leader in such things![]()
Hi
Then some pads Under the backplate are probably a good idea, I did see a post somewhere of a guy who also stuck small heat syncs on the backplate above where the ram chips sit then had a fan over them.I am doing..... It's a gaming PC 1st but I am having a dabble for the 1st time ever to try to pull some of the expense back. That said temps hit 102 degrees even gaming. That is hot for ram.
There is no downside to doing it (other than killing the GPU but all it is doing is exposing a design flaw in general imo. ) My work office has electric heating which I am now able to turn off so I doubt I am using much more electricity either.
- Quake II RTX: default settings with ray tracing, 3440x1440 res, walking around a taxing area for c15 mins: core: 68c mem: 98c!!
That may have been me...Then some pads Under the backplate are probably a good idea, I did see a post somewhere of a guy who also stuck small heat syncs on the backplate above where the ram chips sit then had a fan over them.
Wasn't yours in particular but was something along those lines.That may have been me...
It looks awful but it has taken 5 degrees off.
But still 102-106 degrees with that and my side of case off.....
https://photos.app.goo.gl/GiFWZP9na2SZFKtBA
I am going to remove the backplate but need to know where extra pads need to go.
Lol. I cancelled the latter. OcUK missed out on my money as they took way to long to deliver. Worst part is I was only like 70th or something in the que that had thousands. There are people probably still waiting now in that queue.You can blame @TNA for that. Buying up an FE and also a TUF AIB at same time...![]()
Check out post #29 in this thread https://www.overclock.net/threads/possibly-widespread-cooling-issues-on-rtx-3090-fe.1775245/page-2
Some guy from there even made himself a brand new copper backplate!
I seem to be famous (those aren't my pictures).
Some more neater pad mods I've seen done.
All are 1.5mm thickness pads (either Thermalright or Gelid or Grizzly).
