Assassins Creed Valhalla Bench Thread
2160p
60FPS average / 36FPS min
Asus Strix OC, 'stock' clocks
5900X @ Stock (no PBO)
Driver: 461.09
1440p
81FPS average / 41FPS min
Gigabyte 3080 Gamers OC @ 1800Mhz clockspeed and 19000 memory speed
10900k @ 3.7 (base)
Driver: 61.40
https://i.~ibb.co~/rpjWdGn/Assassin-s-Creed-Valhalla202[url=https://~ibb.co~/sF7ZQR4]https://i.~ibb.co~/rZ9VM0h/Assassin-s-Creed-Valhalla2021-2-17-20-32-40.jpg[/URL]
Please can you both provide the GPU core and memory clock speeds? I have no idea what stock is. :)
I'm very much a noob at techy stuff but GPU clockspeed is 1800Mhz
The 10900k is outta the box so is er 3.7?
If I am correct on those 2 figures let me know and I will edit my post with the numbers.
What about the GPU memory speed?
19,000
Maybe I should've added I don't overclock since I'm a new noob to this type of stuff but that doesn't mean I don't find it interesting..
and what you probably find easy I have to google it :P
19,000
and what you probably find easy I have to google it :p
If you use something like MSI afterburner or GPU-Z will report what clock speeds your hitting in actual game. Thanks to Nvidia's boost behaviour, on the clockspeed side of things you will boost higher then what's on the box, can make things fun to pin down sometimes :p
Also as a side note, I think you used custom settings for your run, think ultra-high preset needs to be used :)
19,000
I'll use 1188Mhz.
Graphics Quality need to be set to Ultra High, you'll need to re-run the benchmark applying the correct quality preset first.
old run ages ago I found
94
https://i.~ibb.co~/M15n3MH/ass942.png
RES: 1440p
CPU: 10900K @5.3?
GPU: 3090 @2100/5300
Drivers: 457.30
I see some posts have been updated with missing information will update the scoreboard tomorrow morning.
2160p
Driver: 461.09
1440p
10900k @ 3.7 (base)
Driver: 61.40
https://i.~ibb.co~/rpjWdGn/Assassin-s-Creed-Valhalla202https://i.~ibb.co~/rZ9VM0h/Assassin-s-Creed-Valhalla2021-2-17-20-32-40.jpg
94
RES: 1440p
CPU: 10900K @5.3?
Drivers: 457.30
Scoreboard updated gents. :)
Bench still rocking the 8700k
8700k 5ghz
RX 6900XT
21.2.2
2700core set 2120mhz mem
1080P
1440P
4K
No screenshot at this time but 71FPS
Just seen it for £29 on ebay and bit. Looking forward to joining in the fun shortly....
Edit: Or not! Bloody key was invalid. Awaiting response from seller... :mad:
